Question about Pioneer Car Audio & Video
On my pioneer car DVD player, how can I get the unit to communicate with the truck BCM
Posted by Wayne Wilson on
  • Alphanso Tee May 13, 2019
    Hi Wayne Wilson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
3 Related Answers
Anonymous
  • 113 Answers
SOURCE: avh-p6600
similar but not exactly the same - for a dvd you must also connect a line to the parking brake wire that shows ground when engaged
Posted on Mar 28, 2008
Anonymous
SOURCE: How do I hook up the DVD player to the TV?
Hi, basically you need to put them into their respective slots in the back of the tv. I know this can be frustrating because the slots are all faced downwards, tucked behind this piece. Look at this image, which should be what you are seeing if you're using a Toshiba 26'' 26AV502U, a model similar to yours.
http://www.bestbuy.com/site/olspage.jsp?id=cat13506&type=page&h=387&skuId=9034733&productId=1218010846690&&viewtype=backView&count=0
Look at the four plugs with labeled "Video 1 In." "L Audio" is your white plug, "R" is your red plug(R actually stands for Right [Audio Input]), and Video is your yellow plug. It would be wise to remember this for every Audio/Video cable accepting unit. It makes sense you are putting the cables IN to the tv, hence "Video 1 In."
Now, to tell the tv to read the video input, find and hit the "Input" button on the remote, and it should be one of those options..(there are only a couple to choose from).
Hope these directions worked for you, and enlightened you!
Posted on Jan 13, 2009
Anonymous
SOURCE: AVH-P5700DVD Car DVD Player: how to re-calibrate the touch screen for a Pioneer...
In order to calibrate the AHV-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
Posted on Aug 22, 2010
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
I spilt coffee on my dvd player now it wont work
replace you have short out the circuit in the unit with the coffee
Jul 07, 2009 | Pioneer AVH-P6600DVD Car DVD Player
I might buy a pioneer avh p6400cd
hi there
this pioneer unit is just a CD player with a TV screen/monitor there is no DVD player in it. in order to watch a DVD you need to get the DVD player (sold separately) also its 6yrs old...it was really good in 2003 but since then there have been units that have a DVD,CD,navigation slot built in (this unit has a CD player built in only this means you cant put a DVD in the slot) if its selling for under $150 buy it if there asking over this i would wait and buy a newer system with everything just remember the DVD player for this unit is another cost so you may be paying just as much for this as you would for a newer unit........ so for me to answer your question its an OK unit and there haven't been to many problems with it except the complaints to pioneer about having to buy the DVD player separately........info for you in 2003 this avh-p6400cd sold for $499 but not to many people knew that they had to buy the units DVD player which was sold separately for $359
hope this has helped your deside
Mar 06, 2009 | Pioneer AVH-P6400CD Car DVD Player
Need replacement navigation dvd set for pioneer avic-d3 in dash unit
you may find the guys at maple audio can repair your exsisting unit they are specialists and we in the trade use them a lot www.mapleaudio.co.uk or 01255442180
Jul 17, 2008 | Pioneer AVIC-D3 Car DVD Player
Avh-p6600
Mar 27, 2008 | Pioneer AVH-P6600DVD Car DVD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Car Audio & Video Logo
56 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
