SOURCE: temp lite blinks
Your ballace is most likely out. If not that your light engine is going out. You may be able to get a rebuilt one from www.vancebaldwin.com it will come with a new fan, and ballace.
SOURCE: Mitsubishi hc3000 wont start
When the power button flashes red and shut down that means the system is getting hot...
Follow the procedures below to solve the problems..
If the TEMPERATURE WARNING INDICATOR still continues to flash, call your manufacturer
I hope that helps
Please rate accordingly
Thank you
Computerrep
SOURCE: akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
SOURCE: Screen shuts off. Power lite blinks. Aquos 42"
The TV is shutting down because there is an internal fault.
the most common cause for sudden shutdown is overheating.
Ensure that the fans are working.
More causes for sudden shutdown are:
PSU failure.
Inverter failure.
Main board failure.
LCD controller.
Complete troubleshooting can be found on service manual.
Parts and service manual can be purchased from the sellers below, you may need to give em a call.
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Do not forget to leave feedback.
Many thanks
