Question about Dishwashers
What P meaning on the control panel of dishwasher SB915 ?
Don A
  • 2,577 Answers
That is not found as an error code in the user manual. The manual says to call customer care if a symbol pops up that is not listed in the manual. This is a Westinghouse dishwasher serviced by Electrolux. Here is a page which may be of assistance in contracting Electrolux.
https://www.electrolux.com.au/support/service-centre-locator
Here is a troubleshooting page (but it does not identify the code):
https://www.repairclinic.com/RepairHelp/Dishwasher-Repair/9-89--/Westinghouse-Dishwasher-Troubleshooting
Here is the user manual:
https://manuals.appliancesonline.com.au/sb916sl/sb916sl.pdf
You might in the comment file add what the P stands for if you contact Electrolux. I do not find an explanation on the web.
Posted on Apr 13, 2019
HO 1 code dishwasher will not start
Jenny, I believe the HO 1 (or H: 01) means that the machine is set to delay starting for 1 hour. Continue pressing the "DELAY" button until the readout shows H: 00.
Mar 06, 2016 | Westinghouse SB915
Dishwasher not heating
I am guessing the hot water is not hooked up. Depending on the type of dishwasher and the setup of you kitchen, you can try to hook it up. You will need to pull it out to fix the heating.
Elisa Jed ' http://www.orlandoac.com/
Mar 24, 2014 | Westinghouse SB915
Water not heating
water not heating I need some ideas to fix the problem.
Nov 18, 2012 | Westinghouse SB915
Dishwasher Westinghouse SB915 fills with water for wash cycle but does not wash.
Contact Westinghouse directly to request the wiring diagram.
May 30, 2017 | Dishwashers
My dishes come out clean but wet. They used to always come out dry. Do I need a service or replacement part? I have a Westinghouse touchdry SB915.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2011 | Westinghouse Dishwashers
Hi, we haven't got a manual for our Westinghouse touch dry SB915 dishwasher and the lock has been activated. How do you unlock it?
press hold in for few seconds if not get unlocked you have to get new on and of switch due to this dishwasher switch burns out its popular with this dishwashers power switch burns out
Dec 27, 2010 | Dishwashers
Runs through entire cycle fine but water is cold
you need replaced the control board its very popular with this dishwashers cost around $220 as i have replaced mine
Apr 07, 2010 | Fisher DD603FCSS Dishwasher
Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Dec 13, 2009 | Westinghouse Dishwashers
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
