Measuring Tools & Sensors Logo
P
Patricia Miller Posted on Apr 13, 2019
I have an Acu-rite weather station model 06014RM. The dew point reading is not working. Showing same as temperature.
5 Related Answers
Anonymous
  • 218 Answers
  • Posted on Feb 22, 2009
SOURCE: what is the website address or the url for acu
Acu-Rite is a brand of the Chaney Instruments Co. Here's a link to the company website. They don't have a lot of information, but you can at least get a product manual here. I'm guessing they just import and distribute the products and don't do any manufacturing.
http://www.atomixtime.com/
Anonymous
  • Posted on Nov 15, 2009
SOURCE: Acu-rite atomic clock squeaks periodically, why?
I had the exact same problem, and found the answer on the Chaney Instrument FAQ page. There's no real solution, but here is the explanation:
Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first. Constant, sporadic beeping is generally due to the unit’s ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. Wireless devices that may cause beeping but are not limited to these devices are; scanners; computers w/wireless keyboard/mouse; or other wireless weather instruments. Essentially, any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
Anonymous
  • Posted on Feb 01, 2010
SOURCE: I have Acu-Rite 00754 Wireless Weather Station
Its a remote temperature sensor to read a aquarium or refridgerator or pool water temperature
Anonymous
  • Posted on Nov 03, 2010
SOURCE: need user manual
http://www.chaneyinstruments.com/pdfs/75077.INST.07.VIEW.pdf
Anonymous
  • Posted on Dec 19, 2010
SOURCE: Acu-Rite 00754 Wireless Weather Station
The main thing with this unit is to put the batteries in the transmitter first, then in the base receiving unit. Then you can't really make any setting changes until the unit figures out the correct time through the radio signals it receives from Colorado, or wherever they come from.
2answers
My ACU RITE temperature is always 4 degrees higher then the accual tempeture. What is the problem ?
This all depends where u have your sensor if out doors keep out of sun light and a northern exposure is recommended If your temperature is off on your indoor readings consider where both sensors are
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
Lost instructions for my ACU-RITE model # 1097B MAIN wireless thermometer and need to reset it.
I have a acu-rite weather station and it keeps blinking even after changing batteries, is it garbage now or can it be saved
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Top Acu-Rite Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
