Question about Jandy Pool & Spa
I have a Jandy Aqualink / Auquapure system for my swimming pool. When I switch on my Jandy Aqualink, all pumps start working but then the whole system shuts off after a few seconds
When it shuts down see if voltage from transformer back of bezel board should be 24 volts ac if no bad transformer if ok bad control board
Posted by Carlo Voelker on
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: Jandy Aqualink - Rs, button control red lites on contriol panel
HAVE YOU HAD ANY LIGHTNING STRIKES?
Posted on Nov 06, 2008
Anonymous
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
poolyoda
  • 128 Answers
Disconnect the spa side remote.
Posted on Aug 23, 2009
Kieran Ruppert
  • 990 Answers
SOURCE: Pump starts and stops after few minutes
Sounds like your motor is overheating, This is a sign of windings going bad and sorry to say you will probally have to replace the motor.
Posted on Aug 25, 2009
Anonymous
  • 16 Answers
SOURCE: Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
My jandy pda will not turn on after changing the batteries, any suggestions?
power aqualink system down all breakers turn off PDA then thurn aqualink back on then PDA should work if not need more info
Jun 29, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
How to turn on swimming pool light on
check breaker then check the relay for that aux
Nov 05, 2013 | Jandy Aqualink Rs4 One Touch Control...
Reset pda
turn whole system off then turn aqualink back on then PDA
Sep 23, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
I have an Aqualink by Jandy RS8 pool control system. The system seems to no longer be able to control the heater from the inside panel. By reinstalling a jumper in the heater we can control it outside. I...
This may be the temp sensor or "thermistor" on the heater or on the Aqualink. If you have a book not hard to replace.
Check with your local BBB or Regestra of Contractors. Also look for pool orgnazations like NSPI (National Swimming Pool Instute) or a local servicemans orgnazation. Or call Jandy or go on the web to get their local rep.
Jun 24, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have this jandy aqualink one touch rs control in my pool, but suddenly start to turning on and off by itself
GO TO THE MAIN PANEL AND OPEN IT DISCONECT THE SPA SIDE SWITCH LEAVE OFF AND SEE WHAT HAPPEND FOR A FEW DAY IF OK REPLAACE SWITCH
Oct 14, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink RS4 randomly turns on blower, pump, heater
I have has to deal with the same problem and have found that the spa switch is causing the problem. When I went into the lockout controls menu and locked out the spa switch I no longer had the problem. Once I figured this out and determined the spa switch was faulty I replaced the spa switch and everything is work correctly now.
Oct 09, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink with IntelliFlo VS-3050
Jandy has an e pump.It would be cheaper to go that route.the Inteliflo is not compatible with the jandy system .If money is not a concern the pentair product is the way to go.
Sep 29, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I do have a problem with Jandy Aqualink System
I would lower the freeze setting. It sound slike you are hovering around the temp set for freeze and that is why it is turning on/off. Go into the freeze mode settings and lower it as you would a heater setting.
Dec 28, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
184 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
rogerpaul3
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
