Cassette has slowed down record player does not spin
Hi, there
Since your unit has a CD player, the problem with both the turntable and cassette deck is probably due to the rubber belts that turn both mechanisms losing elasticity or have broken over time (or in the worst case scenario, turned to goo). I don't know your model manufacturer, but turntables often have a clip, or some sort of apparatus, that you can remove to lift the turntable platter up and off. If you can do that, you will be able to see what shape the turntable belt is in. For the cassette deck, more intricate disassembly is required. Replacement belts for both can often be found on eBay or other online sources.I found a video for an ion turntable that might have a similar belt system.
SOURCE: car cassette player
yes the rubber rollers inside your unit have become hard,,and they are slipping, and the unit detects this,, u can purchase a product called re-grip [ for rubber products and it treats the rubber in such a way to make it soft and pliable again ] the product is sold by mcm electronics and can be found online,,, treat the surfaces of the rubber rollers in your unit and it should preform to original specs....any further help please email me at [email protected] hope this helps you
SOURCE: Cassette player not working
Cassette players usually have a little rubber band that connects the motor to the spindles. If everything else is fine, I would suggest seeing if it slipped off somehow (or got cracked and snapped)
SOURCE: Durabrand 3-Piece CD Boom Box w/ Radio Cassette Recorder,
Does it happen when playing cassette or radio? might have a problem with the speaker wires.
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
