SOURCE: Changing program source without remote
Do a web search for a replacement remote control. If you got the tv without a remote, then I'm guessing you don't have a manual either. Here's a link to a free downloadable manual.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e341b6ad1733d53ba32cb47caf24d013&q=Sanyo+DS19330
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
SOURCE: I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
SOURCE: i cannot get a picture on the screen of my tv. I
Hi
Firstly and would remove all the leads from your TV and check them. If after checking your HDMI leads etc... and its still the same then i would reset the TV to the original Samsung settings. This is completed on your remote control by the following........
Turn your tv to standby, on the remote when in standby press the keys on the remote in the following order........ INFO.........MENU..........MUTE.........POWER ON.
You will now notice the picture comes on with the engineers settings in the background. With the direction keys on the remote scroll down to number 12 (RESET) Then press OK or the right direction key, Your tv will switch off and load the Samsung factory settings. Switch the TV back on and go through the setup procedure.Once completed then try your HDMI again.
If it is still failing then there is a strong possibility that your Eeprom IC on your main AV Board is corrupt and needs replacing. This should only be attempted if you have good soldering skills as they are Surface mounted and very small.
My advise if your skills are not that good is just to replace the main AV board (Scart Board) these usually sell for around £50 but WILL solve your problem.
I have gone trough everything i know here that would cure the fault, most times one of the above three will cure this, but im afraid other times its just time for a new AV board.
Hope iv helped some people out here.
Any comments or thumbs up appreciated.
