SOURCE: what size disk i need for camcorder to take picture
Media type: DVD-RW (8 cm) , DVD+RW (8cm) , DVD-R (8cm) , Click on this link for more information , AJ
http://reviews.cnet.com/digital-camcorders/samsung-sc-dc173u-dvd/4505-6500_7-32365185.html
SOURCE: need to know fuel tank capacity and tire sizes please
hi, ı have a problem with my 2006 125 cc 4stroke supermoto, my moto was stopping at any speed first ı thought that there is no fuel .ı filled it up but the same story again.then ı went to the sevice they opened the mikunı ucal carb.and told me that there is some water in it .ok they fix it and mount a fuel filter between the carb and th efuel tank after that my motobike did the same problem agin and ı realised that ıt has a vacuum problem .when it stops ı open the fuel tank cap, ı saw the fuel passing through the filter then ı can turn the engine on .so should ı take the filter off or drill an other whole on the cap ?
best regards
SOURCE: need to know the best way to take gas tank out
You have several of options >
Personally, the tank liner is low cost and works extremely well. Tank removal is an involved effort. You would be well served in getting a service manual for the bike. With the manual you can do more than just fix the tank. One oil change and the manual pays for itself. Now you can do a whole lot more than just an oil change.
Google "service manuals honda" or try your local library. Often guys will donate manuals to the library. You can also go to www.repairmanuals.com and probably purchase a manual there.
THow about a top rating for this answer? Thanks!
Try using an anti rusting agent like CLR. Plug the holes (petcock,vent etc) and swish the CLR around and let it sit overnight in there, your rust problem should go away.
SOURCE: WHAT SIZE PROPANE TANK DOES THE GLO WARM 630 NEED?
The tank size dosn't matter all you need is a feed line This looks like a spicific tank appalaction but just feed it remotely with a normal propane tank and a feed line and save your self the head ache as long as it dose what you want it to do ist cool
