SOURCE: I have a sentient 4 channel cctv DVR with
have same unit colin and was a nightmare to sort but finally did it.
you need to set up port forwarding on your router and set up dydns account and switch on the service on your dvr. enter details on dydns page on dvr.
if you cannot log in via web address provided by dydns try entering your ip add with port your forwarding like this 89.79.89.87:9950
hope this helps
SOURCE: I have a sentient CCTV Hard drive recorder. Was
Unfortunately it is past DIY stage. Consult a service center.
Cheers
TeaCii
If you own website, add
live support almost free
Real
security guard to watch your cctv for $1/day
SOURCE: Sentient 250GB DVR-RW CCTV N63HH - recording for longer peroids
Just reduce the frame rate slightly on each camera or the record quality and it will increase the data retention period.
SOURCE: sentient dvr cctv playback
Hi, I have a maplins sentient model Sentient dvr cctv is there a windows 7 PCviewer programe ?
SOURCE: I have a Sentient CCTV System and now all the
Look for Totally tight cable connections. A break in the grounding causes the interference, usually. It only takes a slight loose connection to have issues.
