Question about Saws
Motor goes in reverse on rock well table saw 34-345
Posted by Carolyn Vanbruggen on
5 Related Answers
Anonymous
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
Anonymous
  • 145 Answers
SOURCE: I have a skill table saw model 3400 type 2. The
I would check to see that ID of the blade arbor matches the OD of the motor arbor, and you are not missing an adapter ring. Then I would get some acetone and a wire brush clean all surfaces where the blade seats. This is also good practice for Jacobs chucks on drills, that allow the drill bits to spin.
Jim
Posted on Aug 04, 2009
A Miller
  • 8404 Answers
SOURCE: i need the wiring diagram for my 10 table saw
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Posted on Nov 03, 2009
Anonymous
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
Anonymous
  • 5 Answers
SOURCE: I plugged in my table
First of all, how did you determine that power was getting to the motor? If you can test for power with a voltmeter at the motor connections themselves and show power then the switch is OK and the circuit breaker is not tripped. Turn off power and attempt to turn the blade " CAREFULLY" and if it moves easily then the motor is probably defective and will have to be replaced. After turning the motor and finding it easy to turn, then turn the power back on and try to start the saw again. Be carefull because the saw may start. If the blade will not turn then the motor is definitely defective and will have to be replaced.
Good Luck!
Posted on Mar 20, 2011
WHEN I USED OLD TABLE SAW WITH UNGROUNDED POWER CORD. I ALSO HAD JIG SAW PLUGGED INTO SAME OUTLET. wHEN I LAID THE JIG SAW ON THE TABLE SAW IT SPARKED AND THE MOTOR ON THE POWER SAW DOESNT WORK. NEX
If you're lucky, there's a circuit breaker built into the table saw motor and a little red button somewhere on the motor to reset it.
When you re-wire it. know that the cord should have a black wire (hot), a white wire (neutral), and a green wire (ground).
When you wire the power cord to the switch, the black wire should be the one that goes directly to the switch contacts and gets disconnected when you turn off the switch. The white wire goes through the rest of the system up to the motor. The green wire grounds out the metal parts that you might touch.
If you have to replace the motor, get a 3450 rpm to 3600 rpm motor. Harbor Freight has one for about $140 before any discount.
I recommend at least 1.5 HP
Sep 16, 2014 | Saws
Powermatic 66 wiring problem
Simple solution: switch two of the wires. Doing so will reverse the direction of the motor. You can switch it at the motor or on the electrical plug end.
Mar 28, 2013 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
How do i replace brushes on dewalt table saw
unscrew brush cap on each side of motor and pull brush out
do it reverse with new one
Sep 07, 2012 | Dewalt Saws
Table saw motor is runnig in reverse
If it is 220 volt,in all probability it is 3 phase. There should be4 wires coming into the saw motor, 1 goes to the ground, the other 3 go to the motor ,reverse any of 2 of the 3 wires. It should work
Jul 15, 2011 | Garden
Band saw is going in reverse how to i fix that
The motor is AC (alternating current) and only runs in one direction. Therefore, the only way to reverse the saw blade direction is to flip the position of the motor 180 degrees. The teeth of the blade should be pointing down and face to the left when you are standing in front of the saw. The blade should travel down into the table so the blade pushes the work into the table. I hope this helps since it sounds like the blade may be installed incorrectly.
Mar 22, 2011 | Wilton 14in Woodmetal Cutting Band Saw
Bosch table saw turns backwards
The field around the motor needs to e replaced. It is kind of simple if you feel up to taking your saw apart. I had the same problem and a wire on the field had burned I noticed it when I pulled the part out.
Jan 30, 2011 | Bosch Saws
I was cutting 2" dense foam insulation board,
The problem you have is a faulty field coil, the Bosch saws unfortunatly have a bit of an issue with this. The coil can be replaced separatly so you won't have to replace the whole motor. Bosch has a 1 yr warranty on thier table saw so this is a warranty replacment provided the saw was purchased within the year. If not the coil replacment is still cheaper than buying a whole new saw, but should really be done by a service center because of the level of difficulty of the repair.
Nov 10, 2010 | Bosch 4100 10" Worksite Table Saw
Nut that holds the blade loosens after one cut. saw also runs loud and rough. believe is it related to the "gears" and cause of the nut loosening.
Sounds like a bearing is shot and rattling up the works there. Rock the blade back and forth and see if there is any play in it, check the bearing at the other end of the shaft. Is this one of those skil saw motor saws? Or is the motor hanging down below the blade? Need to know that before I can tell you what it is.
Mar 14, 2010 | Craftsman 10" Table Saw
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Nov 02, 2009 | Craftsman 10" Table Saw
Miter saw motor is running back wards
I'd say it was the new wiring that was reversed. Motors cant really start reversing themselves on their own and the only other way it would seem reversed is if the blade was put on backwards...
So yes I think you have the wires reversed when you re-wired the cord.
Please rate this solution on FixYa!
Jun 21, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Saws Logo
143 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
