Question about Midland Radio Communications
How do I programe my midland 40 channels cb transceiver
Posted by clayton smith on
ray gallant
    Top Expert:
  • Midland Master
  • 69,201 Answers
NOT SOMETHING THAT YOU PROGRAM . YOU JUST TURN IT ON THEN SELECT THE CHANNEL YOU WANT TO USE .
Posted on Apr 12, 2019
5 Related Answers
Anonymous
  • 1139 Answers
SOURCE: midland 75-785
Given the fact that when you key up the mic you should not hear any thing because the receiver section is "turned off" (no antenna and the speaker is muted). This would seem to indicate that the switch the headset controls which allow the change over from RX to Tx is bad or that the circuit in the CB unit which the head set plugs into is having a problem. Do you hear the same flutter without the headset? Try to get another headset or test one out just to see if the problem is eliminated by using a known good headset.
Posted on Sep 04, 2007
wyoed1
Ed Meshechek
  • 211 Answers
SOURCE: midland cb model 13-895
Hi Frank, It sounds to me like you may have a bad dectector diode. Other possibilities are cold solder joints in the stand up boards in the IF section. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
Anonymous
SOURCE: CHANGING FROM FREQUENCY TO CHANNEL MIDLAND 75-822
Some models of the 75-822 do not offer this as a feature. Instructions for it are not included in the manual. I recently encountered a refurbished model packed with a manual such as this. Pressing and holding the "F" button toggles between Channel number and Frequency number display.
Posted on Mar 25, 2008
Ekse
  • 13434 Answers
SOURCE: Radio Shack TRC-502 cb radio
Here is the owners manual I'l see if I can get my hands on a internal schematic
http://support.radioshack.com/support_electronics/doc62/62220.pdf
Posted on May 14, 2008
informatica
Greg Cann
  • 1114 Answers
SOURCE: Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 31, 2008
Why wont my midland cb change channels
make sure the channel 9/19 switch is off / set to normal
Jun 09, 2014 | Midland 4001 40-Channels Base CB Radio
Purchased a midland 75 785 from u s will it work on u k channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
Oct 29, 2011 | Midland 75-822 40-Channels Handheld CB...
Midland 75 785 purchase from us will it work on uk channels
  • Hope this helps.
Oct 29, 2011 | Midland 75-785 Handheld CB Radio
I have purchase a midland 75785 cb isit compatable with uk chanels
  • Hope this helps.
Oct 29, 2011 | Midland 1001Z 40-Channels Base CB Radio
What services use radio frequencies from 46mhz to 46.390 mhz
You have not told us which country you are in. You are probably in the UK since that is where a radio covering 46-46.39MHz is most likely to be found. The frequencies are generally not used in the UK. Be aware that radio transceivers with this coverage are still illegal to possess, use or offer for sale in the UK.
Nov 26, 2010 | Midland 40-Channel CB Radio CB Radio
Midland 77-250k No RX nothing, TX perfect on
Best course of action is to ship it in. www.Dodgem250.com
Apr 10, 2010 | Midland 77-250CXL 40-Channels Base CB...
I need help please
Make sure you have the CTTCS codes the same on each radio! Also PMR446 radio's wont be able to talk to GMRS radio's
Aug 30, 2009 | Midland 75-822 40-Channels Handheld CB...
Midland 75-822 CB
http://www.midlandradio.com/comersus/store/catalog/75_822.pdf
Mar 16, 2008 | Midland 75-822 40-Channels Handheld CB...
Jun 17, 2007 | Midland 75-822 40-Channels Handheld CB...
Radio Communications Logo
126 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
Michael Thomas
Michael Thomas
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
