Question about Saws
Vinyl fence installation - Saws
Posted by London on
How to install a fence?
Waht fence do you want to install. Is it a boundary fence? I ask because a radial arm saw also comes with a fence. It is always better to give too much info than too little.
Oct 16, 2017 | Saws
I have a fence that is 1100 linear ft how much sq ft is that
Normally, there is no conversion needed between linear feet and regular feet. Linear feet is just simply stating "1100 feet in a straight line". Etrix_new is exactly right, we would need to see if the fence would be laid in a straight line, or if there would be turns and different heights. Respond back if you can! http://www.holmanfence.com/pvc-fencing.html
PVC Railings Gates and Vinyl Fencing
Jun 19, 2014 | Heating & Cooling
I need some kind of fence with at least 1 gate. I have vinyl fencing on both sides in the back yard, but it's only privacy fencing to separate the yards. I have 2 small dogs and I can't let them out i
You could probably continue the vinyl fencing but that will cost a lot. You could always use a chain link fence which is really cheap and easy to install but it won't look right.
Aug 08, 2013 | Sport & Outdoor - Others
How much should a wooden fence cost?
Of course it depends on the dimentions of your yard. Wooden fences can be quite expensive. look at this site, it includes installation costs:
http://www.homewyse.com/costs/cost_of_wood_fencing.html
Jan 31, 2013 | Home Fencing
What is the best fence I can use for my dog?
First, try to get a fence made from a durable material like aluminum or a wire fence. Of course you will compromise the looks...
don't get a wooden fence unless it is more expensive since big dogs tend to ruin them
Fencing
I am trying to install some heavy duty mesh fence to round fence posts. The corners are difficult because the posts were to far apart(11') to use the same 3.5 diameter that I use for the post for the corner rails. The best thing I found for it was 3.5 in square after doing a lot of research. Now I am not sure how far above the bottom of the pole to install it. I was going to use lag screws to screw it threw the fence post into the square top rail. Where should the top rail be in relation to the top of the wire mesh? The mesh is 4' high. Right now I have a 2" gap.
Apr 02, 2008 | Computers & Internet
Saws Logo
148 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
