Question about Hisense Televison & Video
I have model rev 8 sky remote and a hisense LCD3233EU cannot find one code online to pair my remote with the tele can anyone please help
Posted by Bob Sans on
2 Related Answers
Anonymous
  • 403 Answers
SOURCE: I need a sky remote control code for a UMC LCD
Most remotes work the same when programming an item. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Posted on Sep 25, 2009
Anonymous
SOURCE: code for sky plus remote please
Hi, the code is 1130, i have the same television and the code works perfectly with a rev 8 sky+ remote.
Posted on Mar 26, 2010
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
I am looking for the Sky remote code for a Sony KDL-40V2000 TV can you please help.
Sky don't have a specific code listed for this model yet, so the first thing to do is try the Generic Sony codes first. These are:
1679, 1533, 0678, 0681
These codes are for a "Rev 8" Sky remote. If the above codes don't work or you need further assistance, please post back and I will investigate further. When posting back, please state which Sky remote version you have and whether it is also Standard Sky, Sky+ or Sky HD. The version number can be found on a sticker inside the battery compartment. RC1600/00 is the old original. Newer remotes will also have either "Rev 4", "Rev 6" or "Rev 8" on the sticker.
Please note that Sky remotes wont work with all TVs. I've been informed that a new revision of the Sky remote is due soon but I have been unable to verify this.
Hope this helps. Please post back with the information requested above if you need further assistance.
Regards,
BElectric
Nov 21, 2010 | Televison & Video
Could you tell me sky remote code for technika model 22-220
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says REV 4, REV 6, or REV it might work with one of these codes:
1177 or 2011
However, according to Sky you need the VERY latest Sky remote to control the Technika 22-220.
Personally, I thought REV 8 was the latest version, but it seems they have a newer one. I can't find any reference to it or anyone selling it though - even Sky themselves.
Try the 2 codes above and report back.
Oct 14, 2010 | Televison & Video
Code for sky plus remote please
Apr 04, 2009 | Televison & Video
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
BOUGHT SAMSUNG LE40A656 LCD CAN,T GET SKY REMOTE TO WORK
I tried the closest model no. in the Sky list in the system setup, I think the code was 0840. Cover the front of the remote and press TV, then press red & select button until the remote led light blinks twice, key in the code 0840 and then press select.  Try the volume button and this should work.  If you get stuck go into interactive and system setup and select setup of sky remote and it gives you a list of makes and models, this is the closed one to the LE40A656 and works with mine.
Hope this works for you.
Jan 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Sky remote code for LG 42LC46 tv
Hi - I also have the LG42LC46, i got it to work by using code 206 but you need a REV 8 remote, i tried it with a REV 4 and it doesn't work.
Regs
Dee
P.s. let me know if it worked for you.
Mar 20, 2008 | Televison & Video
Sky remote codes
With an up-to-date remote (rev 8 remote) the 4-digit code 1280 definately works for the LG 32LC56 model coz i have just done it.
Jan 22, 2008 | Televison & Video
Samsung plasma tv
Samsung codes for sky reomte 0060 065, 584, 037, 245, 476, 398, 516, 292, 318,
037
Click here for the link
Jan 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Televison & Video Logo
53 people viewed this question
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
