Question about Watches
Keep on saying hitting up but not working.as we left it on for 3 hours. need to know what to do
Posted by Marina Kloppers on
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
How to set the time on a modelADP6080
Push and hold top left. It will say 'LIGHT' in the bottom screen. Push bottom left until it says 'HOUR' then use the right buttons to adjust up and down. Hit bottom left to move onto 'MINUTE' etc. Learnt by trial & error because it came with no manual!
Jun 15, 2014 | Adidas ADH6080 Watch
How do reset a shake n wake to 24 hour time
SHAKE N WAKE: TO CHANGE TO MILITARY TIME
Hit Mode 3 times to set the time
Hit Reset/TimeSet twice to make hours flash
Now keep hitting StartStop/Adjust repeatedly. After you go through 12 hours of AM then 12 hours of PM it will start going through the hours in military time.
Mar 12, 2014 | Maxi Aids Shake n Wake ZZZ Vibrating Alarm...
Cannot set time on my new Adidas Response ADP6005 watch. manual is useless in this regard
Just talked to Adidas. Manual is wrong on this watch type. To change time: press top-left button "set/light" and hold till "light off" appears. Then, hit bottom-left button "mode," toggling until you reach the hours/minutes/etc. Use top-right and bottom-right buttons to change numbers as needed. Hit top-left "set/light" button when finished.
Jun 16, 2011 | Watches
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    How do i change it from 24 hour to regular time?
    When you are looking at the watch you have 2 buttons on the left side, top button being A and bottom button being C. ON the right the top button in B and the bottom one is D. If you press and hold the A button in time keeping mode the numbers will start to flash. While things are flashing, hit the D button and it should switch between 24 and 12 hour times, then hit A again to escape the time setting mode
    Aug 17, 2010 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
    Need to change the time. turn off sound and alarms
    For alarm:
    Hit START and RESET (rightside buttons normally)
    For hour chime:
    Hit RESET and MODE (bottom left and right buttons normally)
    (Hit the button listed first, then press the other while still holding it.)
    Thats how it works on mine, worth a shot. :-)
    Sep 14, 2009 | Freestyle Shark Classic Midsize...
    Setting the date and time on watch
    time:
    hold left button -- hour will appear and begin flashing.
    press right button to set.
    press left button to advance to minutes, press right to set.
    date:
    press left -- date will appear. now hold left until day flashes.
    press right to set.
    press left to advance to month, right to set. then same again for year.
    Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
    Timex Mid Size Sports 1440 WR50M
    If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
    Than follow these steps:
    1. Press Lap/Reset and hold. You should see the time the alarm was set for.
    2. While holding Lap/Reset, press Mode.
    3. Let go of all buttons.
    4. There you go!
    Hope that was a help
    Mar 11, 2008 | Timex 1440 Nylon watch
    Relic digital watch
    Hold down the reset button until the hour digit starts to flash then to change the hour press the start/stop button then to change the minute press the mode button and keep pressing start/stop button until you get to your desired minute and just continue those steps through the date.
    Oct 12, 2007 | Watches
    Watches Logo
    115 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
