Question about Ademco CIA Modem
Ademco 4160-12 was installed in my house in 1987.While exterior painting, the external siren wire is cut. Please help me find new siren and procedure to alarm system. This has at present only local ( siren ) alarm.I did not purchase monitoring.
Posted by survij2 on
russvan
    New Friend:
  • 74 Answers
Any 12V DC siren should work. If you need a manual for the control contact the Professor.
AlarmProfessor.net
Posted on Aug 23, 2010
Anonymous
  • 80 Answers
Any 12 volt siren will work. you my have to replace the fuse. 12volt sirens are available at radioshack, frys electronics and all over the web,
mj
Posted on Aug 29, 2009
What is exterior rendering?
Exterior rendering is the process of applying an external wall covering to the exterior of a house in order to provide added protection to the bricks it's built from.
The external wall covering protects bricks from the effects of weathering and erosion which can, over time, cause both cosmetic and structural damage.
However, the covering alone is not sufficient as this too is susceptible to damage over time from weather and other environmental factors. Therefore, once the wall covering has been applied, it's usually then painted or a wall coating in order to stop it from cracking and prevent damp from seeping through it and into the home. It also requires regular maintenance and re-painting in order to repair any damage that may occur to the paint or wall coatings.
The whole process of exterior rendering is usually carried out by coating specialists like Apex Coating Services.
Oct 27, 2018 | Building Materials
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
The systems is working fine and no indications or warnings on the panels, but you can hear the siren at a low sound at all times. All the zones are working according to the panel and alarm monitoring...
The siren should not receive any power when in idle mode (non alarmed state). If you hear any noise, it receives some kind of low voltage. Is it powered straight from the panel or with external power supply and aux. relay? In any way - use a volt meter and measure across the sirens power terminals. If you have any voltage present check the source.
Nov 18, 2013 | Honeywell Ademco Wave 2 Wave2 Sirens For...
I have a Ge Simon Xt Alarm and i want to hook up a external siren(part 13-950)I received a 4.7 resister with the siren and 50 ft of wire.How do you attach the resister between the red and black wire?Do...
Wire nuts are ok if the siren is indoors. Gel filled connectors are better if you are mounting the siren outside because they keep the connection from corroding. The resistor needs to go between the two wires you are hooking up. The color of the wires you will are are generally red and black. If your siren has a yellow wire, you can use it instead of the red to get constant siren instead of the "whoop, whoop, whoop" sound that sirens usually make. Putting the resistor at the siren will make sure that it is supervised. That means that if someone cuts the wire going to the siren, it will alert you at the panel. If you put the resistor at the panel, nothing will happen if the wire is cut.
May 19, 2011 | GE Security Simon 3 Wireless Home Security...
Have a 748 siren, lost the wiring instructions and need to know what they were. There are 5 wires on the unit. Thanks
The wires are as follows:
Black: Negative (-)12VDC
Red: Warble (+) 12VDC
Yellow: Steady (+) 12VDC
White Lead: Tamper Circuit
Hope this helps.
Apr 20, 2011 | Honeywell 748 - Ademco 119db Siren
Ademco-749 speaker how to install
There are 4 wires on the 749. Two white and two black. The two black wires connect to the bell or siren output of your alarm panel. The 649 needs 6 to 12VDC to work. The two white wires are for a built in tamper switch that can be connected to a zone on your panel if you want.
Hope this helps
Mar 17, 2011 | Honeywell | Ademco Speaker/Horn 749
Need to change alarm code on ademco alarm ststem
We need more information. The answer is different for different models and Ademco has dozens of models. Tell us the model of your control panel, usually on the inside of the panel cabinet door) and we can help you.
Oct 04, 2010 | Ademco 1 Wave 2 Alarm Indoor Siren Vista...
Help with wireless window security alarm
"Zone not ready" indicates the windows sensors are not seeing the magnet piece to indicate the window is closed. Are your sensors built into the window jams or are they external wires you can see?
If you have external wires, look for broken wires or broken/missing magnetic bars.
Did the painters paint the window jams? If so, they may have painted over a sensor, though paint usually does not affect the functionality of a magnetic sensor.
Look for the broken wires or broken/missing magnets.
Also - you should be able to bypass the window zones and set the alarm. Instructions for bypassing a zone should be on the alarm head or available online.
Dec 23, 2008 | Intermatic SP130B Wireless Door/Window...
Ademco CIA Modem Logo
449 people viewed this question
Top Ademco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Ademco Computer and Internet Expert? Answer questions, earn points and help others
