Question about Saws
Do the chicago electric professional 5" dual cut saw have a reset button cause mine died on me while cutting wood
Posted by Ken Kendrick on
5 Related Answers
Anonymous
SOURCE: craftsman table saw
Alright, I have fixed mine, so maybe the same thing will work for two as well. I actually have a slightly different model (113.298341) but I imagine the electronics follow the same basic layout. FYI, I got a manual online through Sears for free.
Mine has a manual reset thermal overload protector to keep from burning up the more expensive stuff. It is the red "reset" button near the main switch that ought to pop out if it gets too hot, and can only be pushed back in when the machine is back down to a safe operating temp. I overloaded my machine, and the protector broke the circuit, BUT the button did not pop out and I therefore couldn't just push it back in. I took out the protector, and although it looked like the circuit should be closed, there was no conductance through the protector. I took off the tiny bolt on the back of the protector, essentially jostled the thing a little, replaced the bolt, and conductance is now restored. I re-installed the protector, replaced the front cover, and now she works like a charm.
So maybe these reset switches often don't act like they are supposed to? I'd recommend just checking everything in the line, beginning with the main power line in. it will contain three wires: the ground will be bolted to the frame, the others will run to the main switch and the relay, respectively. With the machine plugged in, touch your volt meter probes to the contacts on the way INTO the switch and relay, and you should have 120V. Then, check the switch by turning it to the ON position with the machine plugged in, leaving one probe on the IN contact of the relay, and moving the other to the OUT contact of the switch. Again, you'll get 120V if the switch is working correctly. Alternatively, you could just check conductance through the switch directly w/o involving the relay contact, either way is fine.
Next in line is the thermal switch, which was my issue. Unplug the machine and/or turn off the main switch (I do both, no point taking risks). You'll need to unscrew the switch, which is a black plastic cylinder about an inch in diameter with the red reset button on it, and check for conductance by probing the wires leading into and out of the back of the black plastic cylinder. If you don't get conductance, you're in the same boat as me, and try to fiddle with the bolt and restore conductance. Otherwise, it might be the relay or the capacitor on down the line. If not those, your motor might be shot, but we'll hope thats not the ca$e.
Hope this helps guys, I was really surprised that it turned out to be such an easy fix, you just need a screwdriver, a 3/16 wrench (for the bolt on the switch), and a voltmeter that tests up to 120V and can test for conductance. One thing to be very careful of is the large capacitor in the control box. I just stayed away from it, but I would seek further advice on how to test it if you need to. After taking apart a couple of cameras as a kid, I know not to mess around with those things. Otherwise, just use the same good sense you should bring to any fix involving 120V of electricity and a 10 inch steel blade.
Posted on Sep 06, 2008
George Obray
  • 271 Answers
SOURCE: how do you ulock the saw to pull up the blade so you can put the wood underneath to cut
push down gently on the arm and reach around to the rear of saw with your right hand and pull retainer pin the arm should release and allow usuage of your saw.
Posted on Oct 24, 2008
Chuck Bamforth
  • 205 Answers
SOURCE: McCulloch chain saw wont stay running after it
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Posted on Mar 23, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: CHAIN SAW QUITS CUTTING AS IT HITS WOOD.
The make, model, and occationally the serial number help us solve your problem.
Does the engine quit running? (Carburator needs adjustment)
Or does it continue running and chain stops? (need clutch refaced or replaced.) (to aggressive a chain for the size of the engine)
I think you replaced parts unnecessarily. Maybe quicker and cheaper to visit your friendly neighborhood chainsaw shop. A good one can repair it even if they do not sell your brand.
HTH
Lou
Posted on Sep 09, 2009
Anonymous
  • 20 Answers
SOURCE: Chainsaw runs but when I start cutting it dies
you might just neet to clean the air filter and/or the carb.
Posted on Oct 06, 2009
Troubleshooting chicago 7" tile saw
problem power switch
brushes worn
problem armature
circuit breaker for power point
Jul 11, 2016 | chicago electric power tools 7" Portable...
What would cause a new chain saw not to cut
Maybe I'm reading this wrong, but it sounds like you are saying your chainsaw is newer and runs fine, but it just isn't cutting wood well?
If that is the case then it means the chain wasn't sharpened correctly. Lots of guys do it at home and don't file down the raker teeth in front of the cutter heads, so the teeth don't grab into the wood and just nibble at the wood and make fine sawdust. It is always best to get the chain sharpened at a saw shop first so you can get an idea of the correct angles and depth of the rakers etc. After that you can try to match the saw shop for a while with a round file to take off ragged edges unless you have a decent professional saw sharpening unit.
Nov 03, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Dremel multi max stops when pressure is applyed
I took mine apart due to the same reason. Seems like the yoke that fits over the drive bearing is worn or bent to oversize so that it doesn't make a complete rotation. Hence, a very small or no cutting swath. You can replace the drive head for about 22 bucks plus shipping, (dremel parts) or go to Home Depot and get another one for 70 bucks plus tax. Or do as I did and go to harbor freight and get a Chicago Electric multi tool for about 30 bucks. It works fine. I'm not a professional and don't need a 200 dollar one.
May 07, 2014 | Dremel Multi Max Kit
Saw quits after cutting wood for about 5 minutes
Are you sure you have the correct amount of 2-stroke oil mixed in the gas? It sounds like it is overheating. Also check the engine to make sure the fins aren't clogged with wood shavings.
Mar 29, 2014 | Poulan PP3516
Have a craftsman 10 inch table saw model #137.218250, serial #RCW3145. When we attempt to cut plywood or a 2X4 length ways, the motor dies a number of times. Most of the time the reset button will not...
sounds like the reset button needs replaced. Also when is the last time you cleaned the motor area?? When you reset the button is the motor "hot" to the touch and if so could also be a motor problem,, try the reset first
Aug 26, 2010 | Saws
Wood feels like its "pinching" between blad and fence
Possibly the problem is the wood itself. If it is burning both sides of the kerf then it is probably that your kiln dried wood is picking up moisture on the outside from the environment which causes it to bow inwards as it passes the saw. I have even had this problem with plywood. Just keeping timber in an unheated workshop for a while can cause the problem but after a few months it should equalize and the problem disappear at about 15% moisture content. (kiln dried timber should be nearer 10%)
Cut part way along a plank and then mesure the kerf at the end of the plank and at the front of the cut. if it is significantly narrower at the plank end then that is your problem.
These hard woods you mention are always a problem to cut on domestic saws at usually a maximum of 2000 watts . I use a 4500 watt motor in my saw and it will still complain at dry oak, ash and maple etc. especially if they are moving a bit as I cut them. Before I retired I had a panel saw half as powerful again as that and still those hard woods could cause trouble.
Jun 01, 2010 | Craftsman 10" Table Saw
Not cutting through wood. Cuts are diminishing.
Sounds like the wood your cutting through is to hard for your battery powered saw....try one with a cord they work much better, especially for hardwood's.
May 03, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
When cutting wood with band saw saw will cease up
This could have many causes...depending on the model of saw, the wood being cut, the blade you're using, etc. etc.
Check that the blade is correctly installed, up to tension, and sharp. Make sure the wheels run smoothly on their on, and under power. Check the horsepower of the motor, and make sure to keep the feed rate down within the motor's capacity. Finally, don't twist the work being cut to a smaller radius than the size blade will handle, or you will bind the blade in the cut.
If you are cutting wood with pitch or grain that is likely to be under tension, perhaps you need to insert a wedge into the cut to prevent the work from pinching the blade as it continues the cut.
I hope that leads to a solution. Sometimes all you can do is feed slowly and be patient...
Jan 25, 2010 | Saws
Chicago Electric 4'' table saw. I used it to cut 1/4 inch wood then turned it off and it will not turn back on. I tested the outlet that I had it plugged into and the outlet works. I let it set for over an...
inside the motor is a thermal fuse. once it blows nnthing will work. the thermal fuse is within the winding. get another fractional horsepower motor replacement from grainger.
Oct 17, 2009 | Saws
Saws Logo
147 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
