Question about Video Cameras
Digital video camcorder getting lines in video playback I have a zr85 camcorder?
Posted by Osmond Anthony... on
Tony Parsons
  • Video Cameras Master
  • 6,254 Answers
Why ask twice ?
Ebay or mfr - AGAIN
Posted on Apr 10, 2019
5 Related Answers
Nasirm12
SOURCE: Camcorder doesn't record I just see a blank screen with multicoloured vertical lines
It is a manufacturing defect in a chip. Canon is replacing it irrespective of warranty. See below URL:
http://www.imaging-resource.com/NEWS/1128632808.html
Posted on Jun 12, 2008
Anonymous
  • 107 Answers
SOURCE: Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Posted on Dec 04, 2008
Anonymous
SOURCE: ZR85
Hi! If you go to the Canon, they have a trouble shooting section. I copied and pasted some information below. Good luck!
Details Print Friendly Version Issue: How do I transfer video tape recordings to a computer via Firewire?
Solution: Transferring video recordings to a computer ZR80, ZR85, and ZR90
Transferring Video Recordings to a Computer You can transfer recordings to a computer using the IEEE1394 (DV) terminal. With the ZR85 and ZR90 transferring video recordings via USB is not possible.
Before starting the video transferring, make sure to prepare the following:
  • A computer equipped with a IEEE1394 (DV) terminal or a IEEE1394 (DV) capturing board (the IEEE1394 protocol is frequently also called "Firewire" or "iLink").
  • A DV cable (sold separately)
  • Video Editing Software
You can use (1) the video editing software that came bundled with your computer or video capturing board, (2) the video editing software included with your operating system ("Windows Movie Maker" with Windows Vista Home Premium, Windows Vista Ultimate, Windows XP and Windows ME, "iMovie" with Mac OS 9 and later), or (3) video editing software purchased separately, with features ranging from very basic to very sophisticated.
  • The appropriate driver
A driver is included with Windows operating systems later than Windows 98 Second Edition and Mac operating systems later than Mac OS 9. The driver is installed automatically when you connect the camcorder to the computer. No additional driver is necessary or available.
  1. Start your computer.
    (If this is the first time you are connecting the camcorder to your Windows based computer your computer will display the "New Hardware Found" message while the driver is installed automatically.)
  2. Set the camcorder to playbackicon.gif mode.
  3. Connect the camcorder to the computer with the DV cable as shown below. Once the camcorder and computer are connected together the camcorder will display "DV IN" on the LCD/viewfinder. This message confirms that the camcorder is ready to receive or transfer video.
  4. Refer to the instructions for your video editing software to download your video from the camcorder.
    Note: Because procedures for digital editing software applications vary greatly, Canon cannot offer any additional support or suggestions regarding downloading and editing your video. Please refer to the software publisher or your computer manufacturer (if the software came with your computer) for assistance in using the software.
  • Operation may not work correctly depending on the software and the specifications/settings of your computer.
  • If the computer freezes while you have connected the camcorder, disconnect and reconnect the DV cable. If the problem persists, disconnect the interface cable, turn off camcorder and computer, turn camcorder and computer back on and reconnect them.
  • Before connecting the camcorder to the computer using a DV cable, make sure that camcorder and computer are not connected with a USB cable, and that no other 1394 device is connected to the computer.
  • We recommend powering the camcorder from a household power source while it is connected to the computer.
  • Refer also to the instruction manual of the computer.
  • The programs ZoomBrowser EX and Image Browser included with the supplied CD-ROM are intended for use only with images recorded on the memory card.
  • Video recordings on the tape cannot be transferred to the computer using the software included with the supplied CD-ROM.
Posted on Feb 13, 2009
Ranjith Kolary
  • 89 Answers
SOURCE: Video transfer
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
or
There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable.
http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
Posted on Jun 16, 2009
tscmusa
Mitch Davis
  • 95 Answers
SOURCE: Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
Posted on Mar 26, 2010
How do I upload my Canon ZR85 camcorder digital 'mini dv' films for playback on my new macbook air?
You will need something like that
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Family/Video+Capture+for+Mac.htm
Apr 17, 2011 | Computers & Internet
Dec 03, 2009 | Canon ZR800 Mini DV Digital Camcorder
I can playback the tapes but now I can't see anything on the screen when I want to record. The screen is just black. Is something not set correctly?
If your camcorder is Canon ZR85 then it has bad ccd imager problem and that part will be replaced to see live view in camera mode for recording.
Canon offers Free of Cost repair for ZR85 model.
Click Canon CCD Imager Support for details.
Apr 07, 2009 | Canon ZR85 Mini DV Digital Camcorder
Image distorted in both modes canon zr85 camcorder
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced to back in business.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Dec 25, 2008 | Canon ZR85 Mini DV Digital Camcorder
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Playback mal-function
TRY A CLEANING CASSETTE THIS MIGHT PROLONG THE AGONY. HEAD IS DIRTY OR NEEDS AJUSTED
Jan 09, 2008 | Canon ZR85 Mini DV Digital Camcorder
Lines in tape playback
Someone here recommended taping with the lense cap on in a quiet room for 5-10 minutes. When I played it back, no more skipping or gray lines. This worked for me!!!!
Jul 02, 2006 | Canon ZR85 Mini DV Digital Camcorder
Video Cameras Logo
118 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
