Question about Samsung Audio Players & Recorders
How do I play my Samsung tablet thru my teac Sr l200i?
Posted by Neil Haggart on
Livewyre Studio
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 49 Answers
Looks like there is an AUX IN on the front - you need a cable to run from the headphone socket of your tablet to this input https://www.youtube.com/watch?v=TDEaJfbdKP8
Posted on Apr 15, 2019
5 Related Answers
wing_guy_196
  • 56 Answers
SOURCE: Blown transformer
Greetings!
GPX just received this transformer in stock, at least for model KCLD8886DT. You can contact them at 314-621-2881 and follow the prompts (I think selection 2) or contact them via email at [email protected]. The transformer is $15 plus freight. Good luck!
Rob
Posted on Jan 14, 2009
Anonymous
SOURCE: teac sr-l200i, the ipod dock just started
I had the same problem but with a different TEAC docking product.
My TEAC would not recognize my ipod therefore I was unable to control my ipod via the docking station remote control.
Plug your ipod into the docking station and power down (reboot) your ipod. Once the ipod powers down (in the dock) restart the ipod (yes, while in the dock).
Posted on Mar 23, 2009
Anonymous
SOURCE: Iphone 3G and Teac SR-L200i-W
You'll probably need a charging adapter like the Scosche Passport, avaiable via the Apple Store.
Posted on Apr 02, 2009
proiettigino
SOURCE: Right clock time
Hold the memory button on the remote control, wait for the written "SYNC ON" on display and then press the track forward (one on the right with the double arrow).
Now normally set the clock.
Posted on May 28, 2011
Susanfiltz
SOURCE: Cannot get iPod Touch to play on TEAC SR-LX5i
My iPod touch USED to work fine on this device. Until I did an update. It now won't charge or play. I am sure it's something apple does during updates. No way around it.
Posted on Jan 29, 2012
I have lost the AM antenna. Where can I source one as I have no AM reception ?
hi,
you can get a generic AM antenna at radio shack or you can make one, its easy, all you need is a 10 foot piece of wire, coil the wire up in a circle and tape it so its a coiled circle about 5 inches across, leave the two wires hanging out about a foot to connect to the two AM terminals on the radio, the bigger you make the coil and the more coils you make the better reception you will get, turning the loop around changes the reception some
good luck
jm
Jan 09, 2010 | Teac SR-L200i-W Docking Station for Apple...
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
May 31, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
I've found that I can only set the clock using the remote. Press and hold the 'time set' button on the remote, and using the forward and back buttons on either side of the play button, you can change your clock to a 12 hr or 24 hr time setting. Once that is set, press the 'time set' button and that will switch you to the hour, and using the same forward and back buttons, set that. Repeat the process to set the minutes. Press the 'time set' button again to exit out of if, and you're all set!
Mar 23, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
Teac sr-l200i, the ipod dock just started malfunctioning in the last hour. When I dock the ipod there is barely any sound. This is the case for all my ipods on this unit. The ipods are working on all my...
Mar 09, 2009 | Teac SR-L200i-W Docking Station for Apple...
Blown transformer
I also have the GPX under-counter TV, same problem. I believe the transformer is AC-AC, because both wires out are red... I actually have two of these units, one doesn't work at all, the other has enough power to play the radio, but not the TV. I swapped the transformer from 1 into the one that was completely dead thinking #1 had a bad tuner, but the same symptoms exist now in #2, making me think that one transformer is completely gone and the other is malfunctioning. I'll try the VX 79NP on both and try to remember to post the results back here....
Jan 16, 2009 | Curtis KCR2610 7 in. Portable Television
Teac GR-10i table radio
The iPod touch for some reoson is not compatible for some reason. I have an iPod touch 2nd gen and it doesn't work. However it does work with other types of iPod.
Jan 15, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
Dec 27, 2008 | Audio Players & Recorders
Aug 06, 2008 | Teac SR-L200i-W Docking Station for Apple...
Blown transformer
Greetings!
Rob
Jan 08, 2008 | Teac Audio Players & Recorders
Right clock time
Dec 02, 2007 | Teac SRL200i/B Clock Radio
35 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
