Question about Maytag Refrigerators
Http://www.youserguide.com/wiki/Whirlpool_MSB2354GRW_parts-004
http://www.youserguide.com/wiki/Whirlpool_MSB2354GRW_parts-005
See Section 13. The part is on page 4.
Here is a Sears site:
https://www.searspartsdirect.com/model/3wgy1ddk5e-003048
https://www.partselect.com/Refrigerator+test-defrost-timer+repair.htm
Hope this helps.
Posted on Apr 09, 2019
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
Posted on Dec 27, 2008
SOURCE: where is the defrost timer in a maytag plus side
It does not have a timer it has a defrost board it is in the top of the frig in the back right corner under light a thermostat cover in a box and no they can't be advanced or checked.If the element is good and the thermistor is good than the only thing left is the defrost board and usually it is the board hope that helps
Posted on Apr 02, 2009
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
SOURCE: maytag fridge defrost timer location
If this unit has the temp controls in the middle top of the fridge then it is in there.
Posted on Aug 22, 2009
Sep 09, 2010 | Maytag Refrigerators
Jul 06, 2010 | Maytag MSD2456G Side by Side Refrigerator
Jun 14, 2010 | Maytag MSD2756G Side by Side Refrigerator
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Sep 10, 2009 | Maytag MSB2354G Side by Side Refrigerator
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Jul 06, 2009 | Maytag 23 cu. ft. Side-by-Side...
Jun 18, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Dec 24, 2008 | Maytag MSD2456G Side by Side Refrigerator
Jul 21, 2008 | Maytag MZD2766GES Side by Side...
