Question about Freezers
How do I clean the filter on my igloo icemaker
Posted by Mary Comp on
Just received a igloo ice maker followed all instructions it won’t make ice the add water is on and it’s full of water
"The Igloo 100 series portable icemakers that are sold all over for about $100 have several minor issues. For ADD WATER light, there are 2 main ones. The water SENSOR is located at the top right of the unit. Remove the BACK cover with 6 screws on the bottom. Remove the TOP assy with 4 screws from inside the case. When the TOP is off, facing the unit from front, you see the small silver wire at the back right. Clean it AND the screw visible thru the hole in the plastic at the end of the sensor wire. The screw is the GROUND side of the sensor. This fixes many of the issues. But the SENSOR senses water FLOW, not water LEVEL. If the PUMP is not moving water, the sensor assumes you are OUT of water and turns on the ADD WATER light. The pump apparently burns out easily. Remove the PUMP wire connector from the CONTROL BOARD and check for continuity in the motor. Be sure your multimeter leads actually touch the connectors. The connection end is too small for most meters, so probe from the backside of the connector. If motor is good, check for 12vdc at the board side of the pump connector. Plug in, turn on. Should be 12vdc within 45 seconds. See, the water pump comes on first. When water is moving over the sensor, then the board will turn on the compressor and start freezing. "
Aug 27, 2018 | Freezers
My ice maker cycles and stops with ice full light on with no ice made
If ice is in the tray it could be that the heating element designed to slightly melt the ice so it can be pushed out, is open and needs replacement. But you might find that the cost of element is more than a new icemaker. Be careful
Go to attached site for details. parts, prices, etc. Search Over 2 1 Million Appliance Parts
Aug 25, 2017 | Freezers
Where is water filter
As a rule, these units don't have a water filter, you must use one on the outside of the unit
Oct 29, 2015 | Igloo Cooler Igloo Portable Countertop Ice...
How to clean igloo portable ice maker
Maybe scaling has occured, get descaling chemical to clean it. Also remember to remove the dust accumulate at the condenser..
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Countertop Icemaker is only making a few thin cubes every hour , maybe buildup from bad water ! What can i pour in it to clean ?
I would switch off the power, disconnect water and keep it so for a few hours. While power off, clean whatever visible build up you find. And make sure you shut the water valve before disconnecting unless you want another project! After a few hours connect water and power and wait until ice made. Goodluck.
Apr 05, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Freezers Logo
425 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
