I have bought a SWAY Safeway Model no.SCR 101WTS, have put in the batteries & for some reason does not work, works fine when on power, is there something specific do in order for batteries to work. Thanks
Put fresh batteries in by observing the correct direction of each. Be sure the contacts are clean.
contact-us
SOURCE: My daughter has an HP C700 notebook that is 3+
if is not charging then i advice you to order a new one because one battery has a number of recharging if that is meet or is not use then the acid inside cant retain the charge.
SOURCE: Sony DCR-HC40E when turned on
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Make new brackets to lower the sway bar
Testimonial: "cannot lower sway bar do to lift kit below it And lowering it will put it against the tie rods harder."
