Question about Heavy Machinery
New Holland TN 55 lift arms will not lower - Heavy Machinery
Posted by Ray Antes on
What is alternate route for big trucks to Morrison Tn while TN 55 is closed for Bonnoroo?
No local knowledge. Map says TN 127 to TN 287. You can get to 127 from US 41.
Jun 15, 2015 | Miscellaneous
What year is my new Holland workmaster tractor serial numbwe 6235081
http://www.tractordata.com/farm-tractors/006/6/4/6648-new-holland-workmaster-55.html
Feb 22, 2015 | Garden
Harmar AL435 wheelchair lift arm will not rotate in and out (fuse not blown) Winch and extendable arm work fine. Thanx for any help. Gary
Hallo, mayby late but I had last month the same problem. When you open the electric board wirh the rubber cover. It's on the side of the lift. When opend by the 4 screws you see the board. On the left side there is a red block with I think 6 or 8 white mini switches. First take a picture of the standing of these switches. After this you switch every switch a few times. After this your rotation will work again. It's ocydation of the switches. Succes. John from Holland.
Sep 10, 2013 | Harmar Hamar AL435 Lift - Axis III /...
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
Front wheels shake when i reach 50 to 55 mph
This is known as a death wobble. I am guessing that the jeep is lifted which will put of the center of gravity. Try getting an alignment and balance tires first. Then if that doesn't solve the problem move on to check your tie rod ends and ball joints. There are also many parts that may be needed when lifting a jeep to help put most caster into the front axle for a proper alignment. There are longer lower control arms, Shorter upper control arms, longer pitman arm, etc.
Mar 22, 2010 | 2006 Jeep Wrangler
I need to replace my rear sway bar endlink bushings to pass inspection. any directions/assistance?
(Caution ) sway bar end is under pressure.
1.go to AutoZone get new linkage bars or just the bushings depends on wether the bar has grooves wore into them from use and new nuts. 2. Raise and safely support vehicle,3. remove tire, 4.using floor jack safely support the lower suspension arm and raise to remove pressure on the linkage bar between swaybar end and lower arm 5. remove the nut under the lower suspension arm that retains the swaybar linkage ,6. loosen and remove nut at swaybar end. 7.at this time only lower the lower suspension arm enough to remove the linkage bar. install new bushings or bar to the swaybar end don't completely tighten nut at this time.8. install new lower bushing then jack the lower suspension arm back up aligning the lower end of the linkage with the hole in the arm once pressure is lifting the swaybar install the lower nut and tighten at this time Torque top nut to35-47 Ft lb and bottom nut 8-10- Ft lb lower the jack from under the lower arm and install tire lower vehicle ready to go Appx 1 Hr per side
Feb 20, 2010 | 1996 Ford Thunderbird LX
Heavy Machinery Logo
145 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Steve
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
