Question about Dual Video Game Consoles & Games
Dual xnav267bt was settings hit restore to default it went off and won't turn on
Posted by Mike Gfroerer on
1 Related Answer
Anonymous
  • 68 Answers
SOURCE: under settings accidently set to default & it took out all of my music. how can i get my music back, restore my music?
If you have an Ipod, you are gonna need a lot of time. It will take long to sync each one seperately. If it's just an mp3 player, do this:
1.Open up your music folder and copy ALL your music. Do NOT delete it all.
2.Go to MY COMPUTER>then your mp3 device. Click paste. Your mp3 light might flash if you have one - this means it's sending it to your mp3.
3.You will get a box come up on the screen telling you it's copying the music.
4.There you go. Your music is on your mp3 again.
-sigh- if only ipods were so easy
Posted on May 27, 2009
I wanna reset my phone
Open your phone restore setting and input restore .
Sep 24, 2013 | Fonus Car Socket Adapter Charger Dual...
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
My belkin 750 password won't work- Even after reset
If you need to tech support Fix to fix your Belkin Problems Call Belkin Toll-Free Helpline 1-800-341-2047. OR you can visit here : How To Reset Belkin Wireless Router To Default Settings TechVaidya
May 14, 2017 | Belkin N750 DB Wireless Dual Band N Router
The problem is when click on application program it displays fatal error message of error opening driver file how can i fix this?
Is this happening on any program you click on? If so it means a virus has changed your program file associations.
Click Start/Control Panel/Accessories/System Tools/System Restore
When system restore opens select a date and time that was before this problem started happening. Let the system restore run to completion.
Don't worry, System Restore does not destroy any of your data, documents, music, pictures or videos. System Recovery destroys everything and sets the computer back to when you first purchased it.
If the virus won't let you start system restore then turn off your computer and turn it back on, start hitting the F8 key repeatedly until you see SAFE MODE. Select the safe mode option and when it boots up click Start/Programs/Accessories/System Tools/System Restore and from there select a date and time that was before you started having the problem.
If you still have a problem after doing the restore, report back and there is about 30 different little programs you will have to run to get your program file associations set back to their default settings.
Mar 21, 2012 | Computers & Internet
I have the same problem as "krazyjay". The only thing is that i was't playing when it went off. The thing is that i used it a few days ago, and when i turned it off I din't turned it off...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Aug 10, 2011 | Sony Playstation 3 (PS3) Console
I unplugged external drive from my notebook aoa150, and the computer went dead. How could I restore to make it work again? Thanks
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Feb 10, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have acer laptop. wanted to set user password but i went to system setup and the computer locked, requiring primary master Hitachi HTS545025B9ALock please help!
did you set the hdd to be locked?or does it have a password?try to open bios settings>reboot.hit del>then restore to default settings... if this does'nt work;try to do the restoration system..just follow this steps;
1.Before system run hit f8 then click safemode, or read the manual of your machine of what key to hit entering for options.on my machine i usually hit f8 then click safemode 2.your windows start in safemode,then click start>all programs>accesories>system tools>then system restore... 3.Click restore my computer to an earlier time.then click next,select date to when your machine works normally or never unlocked,click next>then click next. 4.The system reboot;pls wait till the process finish..click ok and your done....
hope this help yopur problems...gudluck
Feb 09, 2011 | Acer Aspire 5500 5570-2609 Laptop
Computer hit by WhiteSmoke Virus. How can I reimage the system
Welcome to Fixya
If you are asking on how to restore the computer back factory default. All you need to do is to keep on tapping F2 or F1 key when the computer is turning on. This will take you to the one key recovery software of the computer. Just look for restore to initial back up then you are good to go.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dec 07, 2010 | Lenovo IdeaCentre K210 Intel Desktop...
The timer on my panasonic th50px50u is greyed out and i can't set it. can it break or stop working?
I had the same problem. I fixed it by going to menu > setup > restore to default. I had to readjust my picture settings and relabel all my hdmi connections but it fixed the sleep timer.
Feb 27, 2010 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Video Game Consoles & Games Logo
74 people viewed this question
Top Dual Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Dual Video Game Console and Game Expert? Answer questions, earn points and help others
