Question about Maytag Refrigerators
I cleaned the coils and checked the condenser fan is running. The air coming into the fridge was cold, just not much volume, I popped the vent cover off at the upper center of fridge and I could hear the evaporator fan running. Checked the back wall of the freezer, there was frost on the horizontal openings. I melted that with a hair dryer, although there was probably more I couldn't see without disassembly, the fridge did start cooling and is still cold now some 20 hours later. What is likely to be a permanent fix for this? The damper in the fridge is working properly, I can see it with that cover off.
Check that the return air duct near the bottom of the fridge is not blocked. The air may be going into the fridge but cant get out. It has to complete a cycle where it gets drawn back into the freezer to get cold and then gets blown back into the food compartment. The baffle controls how much or how little cold air goes in. You may have to take the rear panel off the inside of the freezer, there may an ice buildup in there.
Posted on Apr 10, 2019
SOURCE: Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Posted on Sep 26, 2007
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
Posted on Jan 08, 2009
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
Feb 28, 2018 | Samsung Refrigerators
Apr 21, 2016 | Frost Refrigerators
Apr 02, 2016 | Refrigerators
Jun 03, 2015 | Refrigerators
Jun 02, 2015 | Refrigerators
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Apr 21, 2012 | Frigidaire Refrigerators
Aug 07, 2011 | Refrigerators
Aug 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
100 people viewed this question
