Question about Watches
I moved my slimline.with dial off, zone 3 still turns on water
Posted by Dave on
Setting Time on Police Hammerhead Watch PL 13088 JS/02
the three dials are for three different time zones, there is no minutes or seconds.
to adjust the middle dial just push the small bottom which is located on the back side of the watch
Jan 04, 2013 | Police hammerhead pl13088js-04
Tip
Watch glossary: U, V, W, Z.
UNIDIRECTIONAL ROTATING BEZEL
An elapsed time rotating bezel, often found on divers' watches, that moves only in a counterclockwise direction. It is designed to prevent a diver who has unwittingly knocked the bezel off its original position from overestimating his remaining air supply. Because the bezel moves in only one direction, the diver can err only on the side of safety when timing his dive. Many divers' watches are ratcheted, so that they lock into place for greater safety.
UNIVERSAL TIME
The mean solar time of the Greenwich meridian, counted from noon to noon, Often confused with the mean time notion.
VARIATION
In horology the term is usually referred to the variation of the daily rate, i.e. the difference between two daily rates specified by a time interval.
VIBRATION
Movement of a pendulum or other oscillating bodies, limited by two consecutive extreme positions. In an alternate (pendulum or balance) movement, a vibration is a half of an oscillation. The number of hourly vibrations corresponds to the frequency of a watch movement, determined by the mass and diameter of a balance and the elastic force of the balance spring. The number of vibrations per hour (vph) determines the breaking up of time (the "steps of a second hand). For instance, 18,000 vph equals a vibration duration of 1/5 second; in the same way 21,600 vph = 1/6 second; 28,800 vph = 1/8 second; 36,000 vph = 1/10 second. Until the 1950s, wristwatches worked mostly at a frequency of 18,000 vph; later, higher frequencies were adopted to produce a lower percentage of irregularities to the rate. Today, the most common frequency adopted is 28,800 vph, which assures a good precision standard and less lubrication problems than extremely high frequencies, such as 36,000 vph.
WATER RESISTANT or WATERPROOF
A watch whose case is designed in such a way as to resist infiltration by water (3 ATM, or atmospheres, corresponding to a conventional depth of 30 meters; 5 atmospheres, corresponding to a conventional depth of 50 meters.)
WHEEL
Circular element, mostly toothed, combines with an arbor and a pinion to make up a gear. Wheels are normally made of brass, while arbors and pinions are made of steel. The wheels between barrel and escapement make up the so-called train.
WINDING STEM
Element transmitting motion from the crown to the gears governing manual winding and setting.
WINDOW
Aperture in the dial, that allows reading the underlying indication, mainly the date, but also indications concerning a second zone's time or jumping hour.
WORLD TIME
Additional feature of watches provided with a GMT function, displaying the 24 time zones on the dial or bezel, each zone referenced by a city name, providing instantaneous reading of the time of any country.
ZONE
Small additional dial or indicator that may be positioned, or placed off-center on the main dial, used for the display of various functions (e.g. second counters).
ZODIAC
Circular belt with the ecliptic in the middle containing the twelve constellations through which the sun seems to pass in the course of a year.
on Jan 11, 2010 | Watches
Set reserve indicator on invicta 6106
Here is how to set the Invicta 6106 Invicta 6107 and other similar models with the ISASWISS 8173 movement with the following functions:
TIME - DATE - DAY - ALARM - GMT - POWER RESERVE
DO THINGS IN THIS ORDER AND YOU WILL FIND IT TO BE VERY EASY! After you understand how to set ALL the functions you can skip steps later to set individual functions but for now just do it exactly step by step:
1. Unscrew the center crown (if it is a screw down crown) and pull it all the way out (this is position 2) and turn it until you see the DAY sub-dial at the 6:00 position set to the day BEFORE today. There is no QUICK SET for the day on this movement so you must just keep turning the crown and hour hand past 12 midnight and watch the day pointer until it gets to the day you want - the day BEFORE today.
2. Now set the time to 6:00 (am or pm doesn't matter at this point). This is very important because you do not want the time to be between 9:00pm and 12:00pm when you set the date later on - we are using 6:00 just to be safe.
3. Push the crown all the way in - you don't have to screw it down.
4. Now pull out the crown very gently to the 1st position - just one "click" out. Now turn the crown AWAY from you to set the date to the date BEFORE today - this appears in the small window at the 4:00 position.
5. Now pull the crown all the way out again to position 2 and turn it away from you until it goes past 12 midnight and TODAY's DAY AND DATE are showing and then adjust the hour and minute hands to the current time - be sure to set the hour to AM or PM and push the crown all the way in. If you wish to set the seconds exactly - with the crown pushed in watch until the small seconds hand in the sub-dial at 2:00 is exactly at 60 and then pull the crown out to Position 2. Set the time ahead a minute or so and push the crown in when the actual time is the time you have set - you can set it to atomic clock time on the internet or by another watch that sets itself to atomic time.
6. Now the DAY, DATE and TIME are set to current. Now when the hour hand passes 12 at midnight tonight the DAY and DATE will advance correctly.
YOU CAN STOP HERE IF YOU WISH - but you can continue on to set the ALARM and the GMT indicators as follows:
7. To set the GMT hand (the one with the red-bordered pointer) the crown is pushed all the way in and screwed down. Now simply hold the bottom pusher in for a few seconds until you hear a beep - now you can start pushing it and watch the GMT hand moving - one push at a time for small adjustment or hold it down to make it move faster. When you stop pushing it another beep indicates that it is OUT of the setting mode - so if you want to adjust it again just hold it in until short beep and start pushing the lower pusher same as above.
Understanding GMT (or second time zone): Note that the GMT hand time is indicated on the 24 hour dial (think in military time where 3:00AM is 0300 and 3:00PM is 1500) using the very small numbers around the very outside of the dial. When the local time is 3:00PM if GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "15" which is between the 7:00 and 8:00 hour markers. If the local time is 3:00AM and the GMT is adjusted for the SAME TIME ZONE as you are in now the GMT HAND will be pointing at the small "3" between the 1:00 and 2:00 hour markers. So lets say you are in Pacific Time Zone and it is now 3:00pm local time and showing on the minute and hour hands - and for example you want the GMT hand to show Eastern (New York) time which is 6:00pm (in military time that is 1800 indicated by the very small 18 which aligns with 9:00) - hold in the bottom pusher until you hear a beep - now start pushing it in short increments or hold it down to move it faster until it points to small 18 (large 9). Now the GMT will indicate the hour in the EASTERN time zone while the main hour hand indicates your local time.
7. To set the ALARM - unscrew the crown and pull it to Position 1. Turn it TOWARDS you (if you turn it way from you will set the date which you don't want to do) and you will see the hand with the white pointer and the word "Alarm" in tiny writing on it move clockwise. Set the ALARM to the time you want. Push in the crown and screw it down.
8. To activate the ALARM push the TOP PUSHER once - the small hand in the POWER RESERVE sub-dial will move slightly and then it will move again (give it a second or so) and you will hear a BEEP - now the alarm is activated and the small hand points to the "ON" label. When the alarm sounds if you wish to stop it push the top pusher. But it will stop on its own and then repeat a few minutes later - you can just leave it alone if you wish. Note that the Alarm will turn OFF after sounding - so if you want to wake up for work on time tomorrow be sure the ALARM indicator is pointing to "ON".
9. To deactivate the ALARM when the small hand is pointing towards the "ON" label simply push the top pusher again and and the small hand will move clockwise down to the "OFF" label.
10. POWER RESERVE sub-dial. To align the Power Reserve sub-dial hand (after battery change) pull the crown out to Position 1 and push the top pusher until the hand points to 0%. Push the crown back in and screw it down.
11. Reserve Indicator - the instructions for this movement states that holding down the top pusher for 3 seconds will move the POWER RESERVE hand to the power reserve scale - but this is confusing because the hand never actually stays on the power reserve scale - it will only stay on "ON" or on "OFF".
However - I believe that this is the way it works. When you push the top pusher with the small hand in the "OFF" position it will momentarily move to the power reserve scale and stop for a second before it moves again to "ON" - I believe that this reading indicates the POWER RESERVE just before it moves again to the "ON" position..
Jan 03, 2012 | Invicta Reserve Watches
I have a Kenneth Cole KC1683 watch. I don't understand what the dial at the top left does. There are 3 dials. The main one has the hour and minute hands. There is another small one for the seconds....
It is the dual time zone dial. Set it for another timezone, like London or whatever you're interested in, a timezone your friend is in so you don't call them at 3 in the morning.
May 22, 2011 | Kenneth Cole Watches
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
How to sethour and minute
Thank you for contacting FixYa.
Multifunction watch:Pull the crown out to position No. 3, turn clockwise to go to hour and minutes hands; the small dial showing days of the week will move, and the 24-hour dial will also move correspondingly.To set the date, pull the crown out to position No. 2 and turn clockwise until you have set the desired date; push the crown back to position No. 1.
Best regards. Jewel
Sep 02, 2010 | Fossil FS2919 Wrist Watch
How to set date on it?
Aug 25, 2010 | Fossil BQ9177 Wrist Watch
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
Aug 10, 2010 | Timex Automatic Watch
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Citizen Skyhawk Time Adjustment Problem
It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
106 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
