SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
SOURCE: Front Load Washing machine won't spin, drain or rinse
if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
SOURCE: My washing machine door wont open
Sorry for VERY late solution. I have an LG front loader machine and it has just broken. While surfing the internet, I found your blog. LG front loaders have a weak door handle, that breaks after a few years of operation. All the LG models seem to be the same. Replacement door handles are relatively inexpensive and readily available.To open your STUCK door, I would use a thin butter knife....slide the butter knife between the door and the frame of the machine until you hit the metal latch. Push the latch towards the centre of the machine and open the door.In the interim until you can get it fixed, this workaround method will work, enabling you to continue washing.Hopefully LG will make future models door handles out of cast, or something stronger!
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
