I tun off the closed captioning off and it pops right back up on Toshiba CT-90325 remote
What's your source for the video? For video from a set-top box (Blu-ray. cable box, etc), you have to disable captioning at the source. The TV's CC control only work for OTA and unscrambled cable channels when the incoming signal goes to the RF (coaxial) ANT/Cable input. If this is your source, press the Menu button. Use the left/right arrow buttons navigate to the Preferences menu. Open this sub-menu (down arrow) and highlight the Base CC mode. Use the left/right arrows to change the current mode to Off. Press Enter and then press Exit to save and exit the menu.
The set-top box may not have an option to control the closed captions from the remote but accessed through the On-Screen Menu. On some satellite receivers that provide a signal to a primary and secondary TV. to enable or disable the captions on the second TV at the primary TV's set top box. Then both TVs will show the captions. On my IPTV box, I need to use a password from the service provider to access the Settings menu. The control for the Closed Captions are in the Hardware > Audio Settings menu.
I hope this helps. Please add a comment with the specifics about your devices/source. I can try to find the directions for disabling the captions for your source.
SOURCE: how do i Program the
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2805204&rpn=undefined&modelFilter=40E200U1&selCategory=2797337&selFamily=2838040#
Page 49
The CT-90325 remote is not actually a universal. It's made to control certain DVD players through the HDMI port with something called REGZA-LINK. If you have said DVD player the link provided above and corresponding page number should be the answer you are hoping to get.
SOURCE: my remote Ct-90325 for a toshiba tv keeps saying not available when I press any button
My only suggestion is to read the owner manual to see if the set has a lock out feature that stops the remote from doing any functions.
SOURCE: my remote CT-90325 is saying not available when I use it to turn on tv
The remote control do hot recoganize the set. You have to setup it with your TV by using setup codes. You haven't given any details about your tV here. Then, how can one post a solution to your problem?
SOURCE: toshiba 27AF44 closed caption
It will be so related to universal remote controls. All buttons won't work with what it should be meant for. The only thing we can try, is to try an other setup code. Try that.
