Question about Saws
Pump keeps kicking off and has to sit before it kicks back on. Currently not kicking back on. Would the grinder need to be pulled and cleaned? How do we do that?
Posted by Kathleen Beattie on
5 Related Answers
Anonymous
  • 27 Answers
SOURCE: honeywell rth7400 keeps turning furnace on
check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Posted on Nov 26, 2008
Rizwan Noori
  • 30 Answers
SOURCE: Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Posted on Feb 01, 2009
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: Generator hard to start. Kick back
This sounds like the timing is off. Remove the spark plug and pull the cord to see if there is less tension. If there is less tension then you know that the pull cord is fine. Do a compression check on the cylinder, it should be around 100psi. Remove the valve cover and check to see if valves are moving when your pulling the cord. The valves could have came off the rockers.
Posted on May 20, 2009
Anonymous
  • 59 Answers
SOURCE: eagle 1 6.75 hp heavy kick back after several pulls won't start
check the fly wheel key
Posted on Jun 26, 2009
muttandjeff
Allen Neal
  • 359 Answers
SOURCE: my heat pump runs most all the time i will set the
therostats have what is known as off-set deflection , or simplely put the plus or minus of the temp range which the heat turns on or off this setting is adjustable on many thermostats i usually set for 3 degrees if it is set for 1 or 2 it will run all the time refer to owners manual to see how to set this in program
Posted on Jan 08, 2010
Not enough suction
It sounds like it is a jet pump in a deep well. You probably will have to pull the foot valve and clean or replace it. Because of cost I would suggest getting a qualified repair person to check it out.
Jan 23, 2014 | Flotec Plumbing
Flashing dregdrawer and descaling lights
Descaling helps, but right answer is grinder is stuck. Power down, restart, let it run its start up cycle. before you hit the coffee brew button, use a magnet in place of the coffee bean lid. this will trick it that I has a lid on it, then grab a 10mm socket with extension and ratchet. You will click the coffee brew button while turning the grinder counter clockwise immediately with the 10mm socket right after you click the button or same time if you can manage. Turning the ratchet quick enough for it to slide off as it the grinder starts to spin on its own. I did this twice, kind of a kick start to the grinder. it will dislodge whatever is blocking it and BAM, complete.
The pump will not work if the grinder is not spinning to brew a coffee. so you have to jumpstart the grinder, grind the beans, tamp it and then the pump runs water through it.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
NOT POMPIN WATER OUT.I CAN HEAR POMP GOING BUT NOTHING HAPPENS
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 29, 2011 | GE Nautilus 24" Built-in Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
I need to know where the reset switch is for the fuel pump.
the reset switch is located at the front "a" pillar near where your foot would kick, sometimes called the kick panel for this reason.....the switch is called an inertia switch becuase it shuts off the fuel in the event of a collision, now im from australia, where the driver sits on the right and the inertia switch is on the left, it is behind the plastic panel, be careful not to break as you bend it back,,,,,,,good luck
Jul 28, 2010 | 1998 Ford Explorer
1986 kx500 has mis fired a couple of times but kicked up & sounded fine then just cuts out kicks back up but keeps cutting out???
If its had fuel sitting in the carbies for over 3 weeks, or hasnt been used for a while You will have to clean the jets...
Jul 02, 2010 | Motorcycles
Drain pump keeps running
Probable motor control board problem.
don't buy a GE anything!
May 03, 2010 | GE WBVH6240F Front Load Washer
How do I clean my injectors on my 93 caprice.Its been sitting all winter.And I went to start it and it would only keep running with shots of starting fluid.I put stable intank before winter ,but didnt...
Do you hear the fuel pump kick on when you turn your key on? Should be a buzz for about 2 seconds. If you do not hear the fuel pump kick on then try banging on the bottom of the tank with your hand, sometimes that will get the pump to kick back into working again, but know that this trick only works a few times, may be time to replace a fuel pump. The only reason I suggest this is because you stated that it sat all winter. As far as cleaning your injectors-you can pull them out and maybe soak them in a cleaning solvent but i would try to see if your pump is working first. You can also check the schrader valve on the fuel rail to see if you are getting fuel up to the engine.
Mar 20, 2010 | 1994 Chevrolet Caprice Classic
A.c compressor kicks on and off
How long has it been there, without experiencing any problems? This just start recently? Have you cleaned intake air filters at ceiling? Fan keeps running?
Jul 18, 2009 | Coleman Mach 15 Air Conditioner
Saniflo pump has a delay, kicks in 15 mins after flushed.
Either the rubber membrane or the microswitch is at fault.
Feb 24, 2009 | Saniflo Sanibest Grinder Pump Only 013
Saws Logo
135 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
