Question about Seagate Computers & Internet
I need controller for (English please)
in a computer,. or DVR or what, where does this HDD go?
Medalist 4310 (ST34310A)
built in 1999 (20 years old ) why use any drive this old.
why? it's useless.
my wild guess, is this
you have a PC and ustated PC has SATA only ports (modern)
and this old old HDD is PATA drive, with ribbon cable wide.
and you think it can run on modern PC.
well they do sell cards (PCI-e) that fit and work.
4.31GB is the size , holds about 1 top movie .
are you going to boot from this drive, if yes, very complex answer I will skip here. (ask maker of card , if it can)
newegg.com has them all, any thing you can dream of , is there.
if you look.
https://www.newegg.com/Product/Product.aspx?Item=9SIA4UB8ZU9127&Description=pci-e%2c%20pata%20IDE%20card&cm_re=pci-e%2c_pata_IDE_card-_-17Z-0007-00AF2-_-Product
again, no PC stated, no OS stated.
nor of booting is needed to the PATA relic drive. from 1999.
Posted on Apr 08, 2019
SOURCE: controladores para una pc de escritorio alaska inc vt8233 ac`97
necesito que me dingan donde puede descargar los controladores de audio y video de una computadora alaska, pentium 3, M6VLR Ver: 1.1.
Posted on Sep 25, 2008
SOURCE: Drivers,,controladores...
Drivers are already preloaded for your camcorder as long as you are using Windows XP or Vista. You will need a program to capture the video to your computer. Pinnacle Studio will work for your camcorder.
Once the firewire cable is installed and the camcorder is turned on, pinnacle studio will give you the option to load itself up.
Posted on Oct 31, 2008
SOURCE: ACER MIRASCAN V3.20 NO ME SIRVE PARA VISTA
puedo coseguir los discos de instalacion para acer scan320 u para window vista
Posted on Mar 15, 2009
SOURCE: controladores para windows xp
Yo tengo los controladores, pero los puedes buscar en la pagina de rapidshare. yo los descarge de ahi y me funcionan correctamente.
mi correo [email protected]
Posted on May 18, 2009
SOURCE: Necesito los controladores para un Acer ScanPrisa
Estos sirven para win7, los he probado en x86, no se si funcionen en x64:
http://driverscollection.com/?file_id=19052
le da en download file, descomprime e instala setup.exe (es multilenguaje) y reinicia y listo.
Los controladores se instalan bien, pero no creo que le funcionen los programas que instala (muy viejos), le recomiendo que use el ABBYY finereader (muy bueno) para manejar los escaneos, para el OCR (convertir imagen a texto) o escanear imágenes con Photoshop.
Espero que le sirvan.
Posted on Jul 23, 2010
