Hey! If your speakers work when you run the automatic setup for channel control and balance (FL, FC, FR, RL, RR and subwoofer) the the culpret is probably a button on the front panel (to the left of the volume know called "Digital Input". With a component on and running an audio signal, push that button until it cycles through the list of available inputs. You may find that this will fix the problem.
This has happend to me a couple of times, when one of the kids has accidentally pushed the Digital Input button while plugging in an aux source.
Hope this helps.
Stereo Tech: Check speaker switch(A or B) also be sure you have selected FM, AM, Video, CD ect., somtimes if you do not have a stereo signal the unit will mute best to fist try tape or CD input. Hope I helped good luck.
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
you will need 6 equalizers or 3 stereo equalizers.
connect the 5.1 analogue outputs of your media player (DVD Player) to the equalizer and then connect the analogue output of the equalizer to the AVR.
now you can equaize the sound for extra boost and cut.
Warning: it is not recomended to do so unless you have a powerful amp and high quality and higher wattage speakers, as equalizers are ment to be used mainly for entertianment zones and outdoors in professional applications.
the home speakers annd electronics are not really capable of taking such electronic stress as they are designed to work indoors in a confined space.
but if you are confident go ahed.
Stereo Tech: yes their is a fuse inside that possibly opened, but does the unit show PROTECT across the display? if not you may have goten lucky and just did a fuse small PC board just behind the transformer. Good Luck
