Audio Devices All of my audio is gone. Everything. I've done everything, it is almost like there was never audio to begin with. there is no sound card detected and there is no way for me to scan for it. my audio driver is not installed.. can you help me were to download some audio driver?? tnx a lot...
Posted by macrose on
Anonymous
    Scholar:
  • 104 Answers
Hi, Firstly if your sound card is not detected then either it needs to be re-seated or it has failed. Is the sound you have an actual card plugged into your motherboard or is it what we call "on board" so actually built in to the motherboard. If it is then you have a problem.
If it is an actual card you can open the box, make sure you will not be voiding any warranty you may have on the machine, then you can carefully unscrew the screw holding the sound card firm and pull the card from it's connectors quite firmly. So long as you don't twist or bend it you will not damage it.
Repeat the actions only in reverse to re-seat the card and screw back in firmly. ( If this does not get Windows XP to detect the card you could try another connector slot if you have one.)
Ok now to the drivers, once the card is detected WinXP will ask for the drivers if it does have them. You can follow the installation wizard and point to where you will have placed the downloaded files.
Ok downloading, can you tell me what the sound card is and then I should be able to tell you where you can download them from?
Let me know
SeaJade
Posted on Nov 27, 2007
Audio Devices
You need to remove device from device manager and to install back audio driver
Mar 05, 2008 | Compaq Presario 5000 PC Desktop
Vaio vgn n31 does not detect motu 896hd
MOTU 896 IS A VERY USER FRIEND SOUND CARD. IT WORK PROPERLY FIREWIRE CARD STANDARD PIN. YOU CAN USE ANY FIREWIRE CARD AND USE NUENDO4 FOR BETTER RESULT
Apr 26, 2010 | Motu 896HD Sound Card
Whenever i turn on my camera its says "Clean Contact area of the card with a dry cloth" I ve done that everything you could think of. It gives you to options Clean Card or Format. I have done both and...
Hello, I had the same problem and resolved it using the following program, which you can download from softonic ( is free ) :
http://pc-inspector-smart-recovery.softonic.com/
Is easy to use, you connect your card to de pc (with a pc reader or the camera ), select the card's folder,the file type (jpg) and destination folder for recovering the pictures and finally press init. After that the program will detect that the card is broken and will ask you to do an intensive inspection, answer yes and you'll begin to see your pictures into the destination folder. The process take a time, but is satisfactory.
There is more programs to do his as "card recovery", but no free
Oct 25, 2009 | Olympus FE-310 Digital Camera
Audio Devices
Kinldy download the updated drivers from the following webiste.
http://tinyurl.com/ysy86c
Download
1. Click Download Now, to download the file.
2. When the File Download window appears, click Save (Windows XP users will click Save) this program to disk and click OK. The Save In: window appears.
3. From the Save In: field, click the down arrow then click to select Desktop and click Save. The file will download to your desktop.
4. If the Download Complete window appears, click Close. The file icon appears on your desktop.
Install instructions
1. Double-click the new icon on the desktop. For example labeled R12345.EXE.
2. The Self-Extracting window appears and prompts you to extract or unzip to C:DELLDRIVERSR12345.EXE. (Example path). Write down this path so the executable (Example - Setup.exe) file can be found later.
3. The Self-Extractor window appears.
4. Click OK.
5. After completing the file extraction, if the Self-Extractor window is still open, close it.
6. Click the Start button and then click Run.
7. Type C:DELLDRIVERSR12345 in the Open textbox and then click OK.
8. Follow the on-screen installation instructions.
Thanks
proton
Oct 27, 2008 | Dell Dimension 2400 PC Desktop
Audio Devices
have you tried to install the drivers
Aug 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Audio Devices
on borad one proably no good i would get new x fi sound card use latest driver from web site those onbord ones dont last buddie thats nothing u can do erther come sup or it dont in device manger
Jun 16, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
Audio Devices
Somehow you must have either deleted you sound drivers or disabled them. you can start by looking in you control panel-sytem-hardware-device manager on the list should be something about multimedia audio controllers if there is a yellow arrow next to that then you must have removed the drivers and thus will need to download them from the manufacturers web site.
Mar 12, 2008 | Acer Aspire One PC Notebook
Audio Devices
no sound when i reformat my loptop lavie ll750ad
Feb 14, 2008 | HP Pavilion dv6000z Notebook
Audio Devices
Onboard Audigy Drivers
Onboard Sigmatel Drivers
try the audigy drivers first, all install instructions are provided on the download page, if it doesn't work, try the sigmatel drivers.
hope this helps,
trin
Nov 19, 2007 | Dell Inspiron™ E1505 PC Notebook
Computers & Internet Logo
57 people viewed this question
Ekse
Marvin
Marvin
