Question about NEC Computers & Internet
How do I change the time on NEC Dterm Seriesi So far I have pressed feature 4, Feature 9 then #
Step by step please
Posted by Donna Malcolm on
5 Related Answers
Anonymous
  • 201 Answers
SOURCE: NEC DTERM SERIESI
You may be right about it coming from another extension! If that is the case you need to return the message by pressing the key, finding out what extension is ringing and answer the phone otherwise the message will never be returned and the message light will stay on.
Quite an annoying feature with many phone systems. Nobody ever uses the feature and people have no idea what's happening when someone else accidentally presses the wrong key at the wrong time.
Posted on Oct 24, 2007
Anonymous
SOURCE: My NEC Dterm Series E 16D-1 does not display the MUTE feature
I have a NEC DtermIPK IP phone at my desk and would like to cancel the feature of my voicemail forwarding to my cell phone.... Can you help?
Posted on Jun 20, 2008
Anonymous
SOURCE: Nec DTerm Series i - Feature Light Flashing URGENT
Thankfully I have found a solution that has worked.
A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
To cancel this setting do the following
Lift the handset or press speaker
Dial the access code 4 + 2 (set as default)
Receive confirmation tone and restore handset or press speaker
I have found the manual at the following link to be the best resrouce ever - very easy to understand
http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Posted on Jul 08, 2008
Brian LaDuca
  • 149 Answers
SOURCE: How do you remove the DND feature on phone model NEC Dterm Series III?
Feature 69 feature.
Posted on Nov 13, 2008
Anonymous
SOURCE: How to change time on NEC Electra Elite IPK? I
You have to be on the root phone or "first phone".
To check various phones -Hit {feature} 4.
Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
Time will flash at top of display and can be adjusted.
If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
Posted on Apr 01, 2009
What steps do I take to change the time on my NEC DTERM 80 phone system? I have already tried the Feature+9+# as well as the Recall+728 but those do not work. The first gives me an error message.
  • 1 Press the "Feature" key on the phone system's main terminal. This is one of the Dedicated Feature keys and is located at the bottom left hand corner of the keypad.
  • 2 Dial 9# to enter the clock setting menu.
  • 3 Enter the hours and minutes using the key pad. For example, if it is 12:15, you would press "1," "2," "1," and "5."
  • 4 Press the "Recall" key on the bottom left hand side of the phone key pad to toggle between AM and PM.
  • 5 Press the "Feature" key to exit the system.
NEC Electra Elite IPK II
  • 1 Press the "Speaker" key located at the bottom left of the phone key pad.
  • 2 Dial "728" to enter the phone's clock menu.
  • 3 Dial the hour using two digits. Use military time for any time in the afternoon. For example, 1:00 AM would be "01," but 1:00 PM would be "13."
  • 4 Type the minutes using two digits ranging from "00" to "59."
  • 5 Press the "Speaker" button to set the time
Read more: How to Change the Time on an NEC Phone ' eHow.com http://www.ehow.com/how_7338757_change-time-nec-phone.html#ixzz1XUGjOOet
Sep 09, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Please tell me how to set the time for my NEC phone.
go to the designated admin phone and press feature # 9
Apr 13, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Change date on the Nec Dterm 80 phone
feature 9 # enter time than feature to save
May 11, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Cannot change time on my Xen IPK Dterm Series i
  • Press Feature, 9 and #
  • Use dial pad to enter hours and minutes
  • Press Recall to change Am / Pm
  • Press Hold to change Date
  • Press Recall to change Day of the week
  • Press # to move cursor to Date
  • Enter Date
  • Press Recall to change Month
  • Press # to move to Year
  • Press Feature button to save
Jan 23, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Change the time on dth 16D-1
If this is an NEC Elite system, you must be on a phone with "attendant" features. By default they are on ports 1 and 2. Try and find an ext 10, 100, 1000 or something like that. Pressing Feature - 4 tells you what port the phone is.
Mar 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
How do you change the time on the NEC Dterm 80 for DST?
Don't pick up the phone
enter Feature button
Hit the number 9 key
Hit the pounds key "#" once
enter the correct tiem
Fit the Feature key again
Done
Mar 10, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm 80
Press feature; press 9; press #; use key pad to change time; press recall to change am/pm; press feature again to when time correct; new time should show.
Feb 28, 2008 | NEC DTU 8D-2 Corded Phone
Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
Jan 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Jan 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTERM SERIESI
Oct 23, 2007 | NEC Dterm DTP 32D-1 Corded Phone
Computers & Internet Logo
32 people viewed this question
Top NEC Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
