Question about Element Televison & Video
I need programming codes for my game changer universal remote to program to my element tv
Posted by Darren Rigby on
    Top Expert:
  • Element Master
  • 76,407 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}..
Posted on Apr 08, 2019
5 Related Answers
Anonymous
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
Anonymous
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
Anonymous
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Posted on Apr 14, 2009
Anonymous
  • 5 Answers
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Posted on Jul 17, 2009
Anonymous
SOURCE: Need code to program universal remote for my Apex LCD TV
i have apex tv 2003 and i need a code for my remote
Posted on Jun 02, 2010
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    Programing my xfinity remote
    About 13,200 results (0.79 seconds) Search Results
      Can't program Comcast remote to Element TV - Comcast Help and ...
      forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
      Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
      Comcast - what programing code to use with element tv find ...
      https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
      what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
      Element Tv Comcast Remote (Tut) - YouTube
      ? 3:19
      https://www.youtube.com/watch?v=ZDBr-hZN2AI
      Jan 20, 2010 - Uploaded by TopBreakX3
      The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
      Comcast Remote Codes for TV - Easy PC Tutorials
      www.easypctutorials.com > Comcast
    Jan 27, 2016 | Element Electronics Televison & Video
    What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
    How To Program A Philips Universal Remote ' Codes For ...
    codesforuniversalremotes.com/program-philips-universal-remote/
    Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
    Codes For Universal Remotes ' Universal Remote Control ...
    Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
    Dec 28, 2015 | Philips Televison & Video
    How do I use a gamechanger remote to control LG TV?
    How do I program ESPN game changer remote control - Fixya
    www.fixya.com/.../t6930391-program_espn_game_changer_remote_co...
    Nov 21, 2010 - how do I program ESPN game changer remote control - RemoteControls question. ... You can also use the "Power Scan method": Turn TV off. ..... I need code for an lg bh100 dvd player .... I need the code for an emerson hd flat screentv using a universal Game Changer Remote control espn edition.
    Game Changer Remote Programing Codes - LuLuSoSo.com
    www.lulusoso.com/.../Game-Changer-Remote-Programing-Codes.html
    We Provide 20 for you about game changer remote programing codes- page 1. ... OEM remote control,OEM quality standard remote control for TV or STB 3. ... ZTH3607Use: universal Place of original: Guangdong China (. ... Samsung Tv Remote ControlCodes List · Remote Control Codes For Lg Tv Lcd · Universal Remote ...
    Dec 18, 2015 | LG Televison & Video
    How can I program a directv remote to operate tv 40" led tv ?
    Marion, Check the attached links,instruction and guides to program direct TV remote. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    http://manuals.solidsignal.com/directvrc64forweb.pdf
    How to program your DirecTV universal remote to your TV with just one...
    Remote Control Codes For Element TVs Codes For Universal Remotes
    May 19, 2014 | Element Electronics 40 in. LED HDTV
    GE 24929-V2 code for Element TV
    Check the bellow link for to find the code GE V2 universal remote
    GE 24929-V2
    Feb 26, 2013 | GE Remote Control. 4-Device Universal...
    I have the instruction book. What devices are you looking to proggram - type and brand??
    Nov 21, 2010 | Televison & Video
    I have 3 remotes here..1 is for the element(does not work)..one is a universal remote for my windstrem cable..(cant find the code0...the other is a ge universal(codes listed do not work)...any help?
    among the above remotes it is easy to program GE universal remote,
    because it has inbuilt code detection program(sucess rate is more than 80%)
    If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
    for your brand or if your brand is not listed, try searching for your codes by
    following the steps below.
    1. Turn on the device you wish to program.
    2. Press and hold CODE SEARCH/SETUP until the INDICATOR
    LIGHT lights, then release.
    3. Press and release the device button for the device you are
    programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
    blink once then remain lit. For AUX, press AUX then the device
    button you are assigning to AUX.
    or try some branded universal remote like philips PH301s,sony RM-VL700 and 900 etc.
    I hope that they will solve your problem
    regards,
    cseian.
    May 21, 2010 | Element ELC-HS321 32 in. LCD TV
    Need code for remote. New remote needs replacing.
    Cable and Satellite content providers control the remote codes,
    and we apologize for any confusion during the remote programming.
    Please try the following codes 10019, 0178, 10178, 0030, 10030,
    0835, 10835, or for Dish Network try 627, 659 or 505. For Fios
    TV (Verizon), try the code 3264. These codes may not work on some
    universal remotes. If there is another code listed for Element
    Electronics in your universal remote control guide, please try that
    code. Refer to the Remote Control Guide under your TV’s model
    number for more information.
    May 09, 2009 | Element ELC-HS321 32 in. LCD TV
    Televison & Video Logo
    126 people viewed this question
    Top Element Televison & Video Experts
    Anthony Ward
    Anthony Ward
    Are you an Element Televison and Video Expert? Answer questions, earn points and help others
