Question about Jensen Car Audio & Video
Jensen eqa-110 speaker wiring? - Jensen Car Audio & Video
Posted by jim hough on
Aaron Wan
This info is on the bottom of it.
Posted on Mar 15, 2020
My speaker wires on my Jensen JHT140 DVD Amplifier System got wet from a flood (3 yrs ago) but three of the five speakers & subwoofer still work & have been since the flood. What are the name of...
Flooding which occurred three years ago could not possibly still affect speaker wires. Have you checked all the connections? Did any of the speakers themselves get wet? Still, if you want to get new speaker wire, just take a short piece from the existing wire to a good electronics place to make sure and match the impedence. They're not "called" anything except speaker wire.
Feb 01, 2018 | Jensen JHT-350 System
Jensen XA 2100 Amp. Need High Level input plug diagram. In other words need to know what each of the 6 pins connects to.
the black wire is ground, white is + and white/black is - that's for the left side speakers and the gray is + and gray/black is - that's for the right side speakers and that hooks up to the speaker wires coming from radio to high level input plug if you need a diagram this is the website http://a248.e.akamai.net/pix.crutchfield.com/manuals/110/110xa2100.pdf and look on page 5 it will show you. please vote and leave high marks. Thank you and I hope i answered your question
Jul 30, 2010 | Jensen XA2125 Car Audio Amplifier
I have a jensen cd6112 radio vol control is not working also will not change bass/tre/ or speakers.Tried reset button but no change .Vol knob won't do anything.
I was installing a speaker and while drilling a spark flew. Didn't think anything of it and finished instalation. When finished the audio didn't work on any of my speakers. I have a jensen cd6112 and the unit seemed to be fine. Tuned in, the lights came on and everything. I hooked a radio straight to the speakers to see if they were blown and they worked fine. Is there a fuse in line with the speaker wires? I would hat to buy another jensen unit and the same problem exist. Any help? Is the jensen unit bad?
Jan 05, 2010 | Jensen Car Audio & Video
How to hook it up to a amplifier
sound source out(dvd-cd player)-------------to teac eqa-5 in-----------------teac out---------to amp line in.
Oct 31, 2009 | Teac EQA-120 Home Equalizer
Dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Mar 28, 2009 | Jensen XS-1010 Car Subwoofer
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
Apr 13, 2008 | Jensen SCR-60 Stereo Cassette Player with...
Car Audio & Video Logo
110 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
