Question about DISH Network Televison & Video
On a dish network box what does the blue bar on the upper right corner mean when it flashes
Posted by Antonio navarro on
5 Related Answers
Anonymous
  • 17 Answers
SOURCE: Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Posted on Dec 31, 2007
Anonymous
SOURCE: aquos Channel Bar/audio bar
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Posted on Jan 23, 2008
Anonymous
  • 81 Answers
SOURCE: veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Posted on Apr 09, 2008
Anonymous
  • 126 Answers
SOURCE: blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Posted on Jun 14, 2009
Anonymous
  • 85 Answers
SOURCE: Channel 3 displays in upper right hand corner
press the display button
Posted on Oct 23, 2009
What does a blue symbol of a man in a circle mean on the upper right corner my status bar? thanks
the blue person is the user profile. This is the android lollipop update in which they have changed the icons and allow you to add other user profiles to your phone.
Dec 13, 2017 | Symbol Computers & Internet
How can I hook up my insignia lcd tv model ns-32lb451a11 to dish network with dish remote?
Is the remote capable of controlling other items check the handbook for the dish system for TV control set up if possible
Dec 24, 2015 | DISH Network Televison & Video
Delete my facebook account
Whatever you need to delete, whether it is facebook or an ap, can be done in the settings menu on facebook. It is located in a drop down menu on the upper right hand corner of the page.
Apr 20, 2014 | Mytopia Lucky Slots
How do you hit the menu 6-1-2-
joy raley,
Press 'Menu' on the upper left corner of the remote, It's a small button with a few bars in it, then press those numbers on the number pad. You can also navigate to the options in the menu themselves.
Let me know if you need additional assistance!
Tommy Faust
DISH Social Media Representative
Oct 22, 2012 | DISH Network DVR-625 DTV Receiver /...
Where is numlock key in dell vostro 1310
Should be located in the upper right hand corner. It may be highlighted in blue letters, meaning that you have to use the blue <FN> key next to the space-bar to imitate it.
Jul 06, 2012 | Dell Vostro 1310 Laptop Computer PC...
Have Dish Remote Access but Remote in upper right corner operates TV 1, not TV 2
Just try an other serup code. Some codes won't work with all. Select a setup code which has maximum functionality. Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
Type in site name as it is, either to google or Yahoo search box [not in the address bar of your browser] and search. Pull up older posts there.
May 15, 2012 | Televison & Video
I have a blue screen with a lock in the upper left corner of the screen. my remotes are not responding. p.s. i have dish network and this is a remote unit
Hey stevennew,my name is Mike Houston of DISH Network and I was going over your post and seenwhere you have a Blue Screen. There is a easy fix to this, if your on TV1 andthe connection from the TV to the receiver is a COAX make sure the TV is onchannel 3 or 4, if your using a RCA cable you will need to go through theinputs of your TV to put it on Video1 or Componet1, I will send a link to helpwith these steps. http://www.dishnetwork.com/SupportSection/video
Apr 12, 2011 | Jensen Q2049J 20" TV
Have a722 reciver uhf remote will not change channels onlly have picture from tv 1
kristinjacqu,
Your 722 receiver may be in single mode. This is the case usually when you have the same picture on both TVs and the remote won't function. On the receiver when it's in single mode, you will have a green light for TV 1 and an amber light for mode under the single box.
To put in dual mode, open the door on the right side of the receiver (the door will open to the right). Once open, in the upper left corner of that area you have a mode button (to the right of the power button). Press the mode button and the amber light will now illuminate under the 2 boxes. The blue light for TV 2 should also illuminate indicating the receiver is now in dual mode. This will separate the 2 TVs and you can now watch different channels on both TVS, plus the remotes will now work. I hope this helps.
Ray Calo
DISH Network
Nov 25, 2010 | DISH Network IR Remote Control
I can't access my mail
hi thanks for using fixya!!
You have to check your Internet Service Provider, contact them, perhaps, you are having a ver y slow connection.
If you need further assistance, let me know!
Jul 01, 2009 | Yahoo Mail
Nokia 500 gps. Display freezes and has a box in upper right corner. Bluetooth hands free works but navigation does not. Troubleshooting info found on Nokia Wiki says "this means the shell is started...
Try this, I have similar issue with the unit freezes and has a box in upper right corner. Go to the Nokia website, download their software update wizard and follow the instruction. It will flash the unit and fix the issue.
Mar 21, 2009 | Nokia N500 Auto Navigation
Televison & Video Logo
32 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
