Question about Husqvarna Sewing Machines
What is a Viking Husqvarna 150 vintage sewing machine worthif it is in really good condition? Also how much is a new home model 641 sewing machine worth if it is in really good working condition?
Posted by Kristi Derschmidt on
Ruth summersides
    Genius:
  • Husqvarna Master
  • 1,477 Answers
Depends on where you live and who would want to buy.
New sewing machines can be bought at Walmart for $99 - $200 with a lot of stitches and extras. :-)
Posted on May 02, 2019
5 Related Answers
RickE1
Rick
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
Anonymous
  • 8 Answers
SOURCE: Need manual for Scandinavia 200 sewing machine
I have one.
Posted on May 25, 2009
Anonymous
  • 52 Answers
SOURCE: Husqvarna Viking Model 150 sewing machine does not work
Make sure the bobbin winder isnt engaged this can cause the clutch to engage and the motor will run but the machine wont sew
Posted on Jul 14, 2009
Anonymous
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Anonymous
SOURCE: Husqvarna Viking Sewing Machine 6020 sews in reverse
Take it in to be serviced by authorized Viking repairperson. I understand that for ~ $175 they will disassemble your machine, remove all the hardened grease from gears, calibrate the gears & set tension correctly, etc. A small cost considering these older mechanical sewing machines are GEMS and will provide you another 60 years of sewing bliss if taken care of properly.
Posted on Jan 24, 2010
How do you wind a bobbin on a Viking 6570 sewing machine?
Unfortunately, I'm unable to locate a web site or video for this beautiful machine. You can get a user manual from Husqvarna/Viking here:
Husqvarna Viking sewing machine manuals
Service manual here:
Viking Husqvarna Sewing Machine Service Manuals
Not your model, but may be helpful:
Demonstration Video of Vintage Viking 6690 Sewing Machine
viking husqvarna 6440 sewing machine
Aug 03, 2017 | Sewing Machines
What does a capacitor cost for Viking 205 model sewing machine
you'll have to contact a sewing machine repair shop for the
information.
Oct 02, 2012 | Husqvarna Viking 1
Operators manual for husqvarna viking sewinmg machine
What is the model of the sewing machine?
http://www.ismacs.net/free-sewing-machine-manuals-list.html
This site will give you 150, 180 and 190 manuals.
Jan 07, 2012 | Husqvarna Sewing Machines
Dog feed with husqvarna viking sewing machine model 6440 does not work
You should join the yahoo group "vikingsewingmachinespre1980". Bill will take very good care of you. I'm new to that group and have gotten every question I've asked answered. This is just for pre-1980 Vikings which includes the 6000 series - including the 6440. Good luck.
Feb 19, 2011 | Husqvarna Viking 1
I need an instructions manuel, it is an old model but in good shape. can you help?
Hi! You can find instruction manuals at http://sewingpartsonline.com/viking-sewing-machine-instruction-manuals.aspx or http://www.sewconsult.com/husqvarna/husqvarna_instruction_manuals.htm (this site has pictures of the machines, which is really neat!).
Hope this helps!
Happy Sewing!
Feb 12, 2010 | Husqvarna Viking 1
Jul 05, 2009 | Sewing Machines
Husqvarna sewing machine
Sorry I'm not familiar with that model but if it is a Husqvarna Viking machine, you can probably get one from an authorized Husqvarna Viking dealer. They should be able to order one if they don't have it in stock. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Aug 20, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
sewcrazyshan
Level 1 Expert
tsalagi152
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
