Question about Homedics Health & Beauty
SOURCE: Faulty Homedics SBM 300H Therapist Select Shiatsu.
My mom had the same problem so i unzipped it from the back, and once i started to take out the padding i saw that there was a wire unplugged so i plugged it back in and it worked!
Posted on Dec 30, 2008
SOURCE: I am connecting 4 nodes through 2 switch located
Did I understand correctly, that your setup looks like this:
- 2 machines
- switch 1
- 400ft cable
- switch 2
- 2 machines
If so, the problem is with the 400ft cable. Ethernet specifications allow for only 100 meters (~325ft) of cable for reliable connectivity. You can push it a little bit, but in your case it's at least 22% more than is allowable. And if there are a lot of interferences on the way, and the cable is of inferior quality, your chances are rather low.
A high-quality cable might help (double shielded, well and uniformly twisted wire pairs), but the most reliable solution would be to put a small repeater/hub/switch somewhere on the way, where power for it can be provided - this should do the trick even easier than laying a new cable...
Posted on Oct 28, 2009
SOURCE: Adapter for homedics shiatsu back
Radio Shack, you need to know how much amps it needs and might have to bring it in to fit the plug.
Posted on Dec 16, 2010
Hi Im looking for an adaptor the homedics company is in the USA i contacted them and they said they do not ship to the u.k
Posted on Jul 28, 2012
SOURCE: How are shiatsu massage chairs?
Shiatsu massage chairs are very good. It would be better you use a vending massage chair before buying one.
Posted on Oct 25, 2013
Sep 15, 2014 | Homedics Quad Roller Shiatsu Style...
Dec 10, 2013 | Homedics Shiatsu Massager
Aug 24, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
Jun 23, 2011 | Homedics Back Massager with Heat
Oct 02, 2017 | Homedics Shiatsu Massager
Dec 16, 2010 | Homedics Shiatsu Massager
Sep 24, 2009 | Homedics Sbm 200 Therapist Select Shiatsu...
263 people viewed this question
