Nikon Coolpix L11 Digital Camera Logo
Posted on Aug 06, 2009
Pictures are blurry - have the red hand flashing
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 27, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
1430
Points
10
What scene mode are you using? On the bottom right of the back of the camera, there is a switch that allows you to choose between Auto, Scene, or Movies. If you are using Auto, make sure you leave the flash on auto. If you are using scene option, some scenes don't allow flash thereby causing blurry pictures. Check the user manual to learn about each scene mode. If you don't have a user manual, you can download one on the Nikon website for free.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
388
Points
Select flash in auto... normally when you turn off the flash. the hand appear...
1 Related Answer
Anonymous
  • 8 Answers
  • Posted on Dec 03, 2008
SOURCE: Pictures are blurry
this is a symbol for a low light condition. Either increase the light by opening curtains using in-direct light or just use a flash.
Canon ixus 65 - when taking a shot without the flash on, a red camera icon appears on screen and the shot is usually blurry. Why?
When hand-held shooting, shaking will cause blurry. So when the shutter speed below 1 / 60 second the vibration warning will appear, open the flash, up shutter speeds, vibration warning disappeared.
Pictures are not sharp
On most camers that means you are going to get a blurry photo because of camera shake. Using the flash should take care of it. You may have the flash set to "flash off" mode accidently, and in insufficient light the shutter speed is too slow to stop blur.
Mar 17, 2009 • Cameras
Pictures are blurry
Taking pictures
Hallo
First, try to use different batteries. it can cause to long reaction times
Second, try to buy a faster memory card, it usually help for the time it takes to upload and see the pictures on the screen
about the blurry pictures
are you using M or a different mode?
2answers
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Canon sd900
Try a higher ISO speed (suggest 400). Look in your camera's instruction book to find out how to do this.
May 27, 2008 • Cameras
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Blurred pictures
WATER + CAMERAS = NOT GOOD!! does anyone besides me see this?
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
