Measuring Tools & Sensors Logo
Question about Measuring Tools & Sensors
I have an Acurite 1099RX. All works fine except I cannot figure our how to set time and date. Help please.
Posted by Sharon Bury on
5 Related Answers
Anonymous
SOURCE: date and time stamp setting
I followed the above instructions but my security code deeps
changing, but I can't change the time....I finally got to Monday
but how to I change the time from 11pm to the time it is now.
Help please......thanking you in advance
Posted on Apr 21, 2008
Anonymous
SOURCE: i cannot change the time on my motorola KRZR
did you restart your phone?
Posted on Mar 09, 2009
Anonymous
  • 2501 Answers
SOURCE: A friend gave me an
You can get instructions from their web site
(www.adidas.com/campaigns/watches_fw07/content/index.asp?)
Click on "instruction manuals" in the menu on the left, choose your country.
You will be presented with a series of generic instructions from which you
should choose the ones that suit your watch.
Posted on Mar 08, 2011
Anonymous
  • 6 Answers
SOURCE: i just bought this watch
set time/datepush the pusher at 4:00 for couple second to start setting mode.pusher at 4:00 is to select time/date, pusher at 2:00 is to adjust time/date
2. if off sync between analog and digital clock happen. You need to resynstep 1: follow the instruction 1 to set digital clock to 12:00.step 2 : push and hold both pushers at 2:00 and 4:00 for couple second until it shows sync modestep 3: once it enter sync mode, you can use pushers at 2:00 and 4:00 to adjust the analog time to 12:00 same as digital.step 4: push the pusher at 3:00 to exit the sync mode. step 5: follow the instruction 1 to adjust digital time to correct time. Analog time will adjust it automatically.
Posted on Jan 04, 2012
senaweemes
winserp
  • 363 Answers
SOURCE: I just bought a philips gogear 8gb sa3vbe08 today
Hello, everyone, have you ever played a game called RuneScape? I heard this game is very popular before, and now there are still many players, and recently I found a website may be able to help you, to share with you www.rsgoldfast.com
Posted on Jan 18, 2017
1helpful
I need help to reset acurite 020010 rx
Battery compartment contains reset button. Press. Will need to re-enter time and date.
https://www.acurite.com/kbase/weather-stations/02031RM_Weather_Station.html
I have an acurite model 13020CCDI I just would like to know how to set up time and year 'I can do the other things
page 6 and 7
Intelli-Time
clock and calendar are pre-programmed to the correct time and
date, and update automatically for Daylight Saving Time. All you need to do is
select your time zone using the "ZONE" button
https://www.acurite.com/media/manuals/13020-13026-instructions.pdf
After changing batteries clock won't reset help
Set the Time & Date
The clock and calendar are utilized to time stamp history records and other data, so it is important to set the time and date soon after you power on the display unit.
Set the Time
1. Press the "up arrow" or "down arrow" buttons until "SET CLOCK?" is displayed on the Selectable Category part of the display unit.
2. Press the "SET" button to set the clock.
3. Press the "up arrow" or "down arrow" to adjust the hour.
Note the "AM" and "PM" indicators.
4. Press the "SET" button to confirm hour
selection.
5. Press the "up arrow" or "down arrow" to adjust minutes.
6. Press the "SET" button to confirm minute
selection.
The clock is now set.
https://www.acurite.com/media/manuals/01010W-instructions.pdf
BACK OF DISPLAY UNIT
1. A-B-C Switch
ID code that must match 5-in-1 sensor’s A-B-C switch to ensure units synchronize.
2answers
Model 1099rx not working,even after I replaced all batteries
If this is for the AcuRite weather station, please contact customer support at: http://www.acurite.com/support
How to reset my Acurite 1099rx after replacing battery
http://www.acurite.com/advancedsearch/result/?q=1099RX
There is no reset button, installing new batteries causes the sensor to reset itself.
Try removing and re-installing the batteries.
Good luck,
Steve
ACU RITE Wireless Thermometer Model L5C0668TX cant set the date
I have misplaced the user manual for the
Acurite L5C0668TXACU RITE Wireless Thermometer Model L5C0668TX. Where can I get another?
1helpful
I have an ACURITE 00590A1-RX. My time is off by 10 minutes. i don't have my manual and would like to know how to reset it. If possible, tell me how to download a manual.
From the manual, such as it is:
Set the Time Manually:
If you want to set your alarm clock a little ahead or if the unit ever loses time for any reason, the time can be set manually by following these steps.
1) Press and hold the "CH./SET" button for seven seconds to begin the manual time set mode. (2 BEEPS) The hour will flash on and off.
2) Adjust each setting by pressing the "+" or "-" buttons. Confirm and move on to the next setting by pressing the "CH./SET" button.
MANUAL TIME ADJUST SEQUENCE: hour, minute, year, month, date
This works for me. You have to be sure to keep pressing the CH/SET button for the full seven seconds -- the first beep the the clock gives you will only allow you to set the time zone and DST function.
Top Measuring Tools & Sensors Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
