SOURCE: My Vizio 37' flat Screen TV Closed Caption wont turn off
If you have a digital cable box, turn off the box but leave the TV on. Hit the "Menu" button on the front of your cable box and a setup menu should come on. Use the cursor buttons on your box's front panel to go down to the "Captions" option, which is probably set to "Enabled" and hit the right or left cursor button to change it to "Disabled." That should solve your problem.
SOURCE: High pitch humming sound when tv is off.
Better not to interfere with it as it should be under warranty if you have just bought it Either retun it to the store or have their service tech come out and look at it. These units are High tension power and are dangerous to try and fix yourself if you dont know what you are doing
SOURCE: DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
SOURCE: how do I hook up a DVD player to a proscan 32 inch
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
