Question about Refrigerators
Today Aldi are selling a 65 litre fridge freezer, how much current doers it draw?
Posted by Elaine Craig on
Andrew Taylor
    Top Expert:
  • Refrigerators Master
  • 33,114 Answers
Google
make model specs
Posted on Apr 05, 2019
2 Related Answers
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: fridge not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
san win
  • 4 Answers
SOURCE: fridge/ freezer not cooling
there has been some leakage of the refrigeration gas or the thermostat has not been set to proper setting, may be in defrost mode.
Posted on Sep 13, 2012
Opening times Aldi Halls Head WA
Greetings from Canada. Amazing how someone in Canada can supply this information eh?
Retail chain selling a range of grocery items, including produce, meat & dairy, at discount prices. Located in: Halls Head Central Address: 14 Guava Way, Halls Head WA 6210, Australia Phone:+61 13 25 34 Hours: Open today · 8:30AM-6PM
opening times Aldi Halls Head WA Google Search
May 26, 2017 | Computers & Internet
Cubic feet of my fridge and freezer model #ED5CHQXVQ00
The model number usually depicts what size fridge it is. ED 5 ?? That would suggest 5 cubic feet. ?? In Australia, fridges are measured in litre size. IE/ a fridge with say a model of HE550 would suggest 550 litres ( a reasonably big fridge)
Apr 09, 2015 | Refrigerators
How do i get heating element out of a westinghouse aurora 440 litre fridge/freezer
its a major repair I suggest sell the fridge and look for another
as the heating element even after you replace it will tend to give
you problems
May 16, 2014 | Refrigerators
Fridge temperature too warm
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
Dec 06, 2013 | Refrigerators
Fridge freezer not freezing
Click means overload tripping due to compressor drawing extra current due to overheating or wear and tear. Check running current mentioned on the specs sticker and if the same is ok. then relay must be checked.
Apr 05, 2012 | Freezers
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
Refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Nov 04, 2008 | Kenmore 53542 / 53544 Side by Side...
Samsung side by side fridge freezer making a nosie
Dear friend,
ngfam at you service! happy to assist!
Are you talking about the freezer compartment only?
Leave the door open over night !!
A hair dryer may get you electrocuted!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 16, 2008 | Samsung RS2630SH Side by Side Refrigerator
Power Consumption Refridgerators
I have a 10KW stik welder/generator. I have no problem running a large freezer and 2 fridges except for the startup current draw. I have a $300 transfer switch connected to a 60amp sub panel with current meters on each leg. I have to watch the current draw and turn on & off breakers. I do have to play the "green acres" game because I have the water heater, well pump, and kit ckt all connected as well. Coffee machine, toaster, oil furnace, microwave all have to take turns as well as the water heater(4500WATTS). Cost was about$3500 in 2001 and $600 for a generator shed. lots of my labor. Last time we lost power it payed for itself. 28 hours without a generator would have been a trip to a hotel and lots of spoiled food to dump. hot shower and coffee anytime a big +
Nov 20, 2007 | Vacuums
Candy fridge freezer
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
Nov 05, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
217 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
john h
