Hi!
Please check the manual to a similar Franklin Chef fridge. Hope it will help you to fix the trouble or to find a contact of customer support/tech service to repair it.
https://manualsbrain.com/en/manuals/1378198/?page=6
SOURCE: My Franklin Chef fwc35 Wine Cellar began leaking
Clogged drain. Pour mixture of baking soda and warm water down.
SOURCE: The alarm in our Franklin Chef model FWC100 wine
Love this machine. Works great. Have had it for 6 years. Now it has a problem. The lights and fan work, and the temperature settings work. It behaves like either the freon is low (I don't hear the compressor starting), or whatever causes the compressor to start is crippled... Fuse looks good, nothing visibly burned on the motherboard, haven't opened the bottom.
SOURCE: Fan doesn't work on oster wine cellar
The outside rear fan on my wine cellar seized and caused the unit to stop working. I replaced the fan with a close match (12vDC, 0.16amp) and the unit is working again. I also took the time to replace the in-line fuse in the upper left corner of the circuit board, just based on all of the blogs I read about it failing. I did all of this only becasue the unit was past it's warranty (>1year) I think however that the main problem with these wine cellars is that the two fans (one on outside, rear and one inside) are just too weak. They can easily be stalled if the air flow is blocked. Oster should have spent a little more money on a good fan and they might not have all of these dissappointed customers.
