Question about Bosch Dishwashers
Bosch exxcel multi programme ....programme gets to 1 min and then stays there. on the quick cycle on the auto cycle it gets to 60 min then returnsto 140min on the timer... thankyou
    Sergeant:
  • 228 Answers
This is caused by incorrect water levels the appliance takes in too little water at final rinse and generates erro code 1 this is what you are getting it isnt 1 minute to go it will need the dishwasher equivalent of colonic irrigation several tubes will be full of fatty deposits,using the quick wash a lot will make this happen more often you will need an engineer to sort but shouldnt need any parts.
Posted on Aug 07, 2009
6ya staff
SOURCE:
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
Bosch exxcel washing machine/dryer
Is it waiting to heat up? Try it on a spin cycle and see if it stops. If not, it may be a thermostat fault or heater element not working. Worst case may be timer faulty
May 21, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
Wash cycle over running
the main control is not advancing properly and needs to be replaced,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 08, 2012 | Bosch Washing Machines
Bosch exxcel programme runs until 1 min left and won't finish
This is a fault code which indicates it has not heated through the programme
Dec 13, 2008 | Bosch 24 in. SGS43C12 Classixx...
Diswasher will not fill clock stays at 130 an
This is either a fill fault or a heater fault, for fill fault check side fill chamber is not blocked with fat, for heater check heater, if heater does not activate then the fault is on the PCB programmer, this model often suffers from faulty soldered connections on the pcd, remoce and inspect if required resolder joint. Regards Advisor
Aug 19, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
291 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
