Question about Bosch Dishwashers
The rubber apron has come loose from my Bosch dishwasher. How do I reattach it?
Posted by Betty Engel on
ray gallant
    Top Expert:
  • Bosch Master
  • 68,537 Answers
PERHAPS GLUE OR POP RIVETS . I HAVE NOT SEEN IT
Posted on Apr 07, 2019
The custom wood panel of my bosch SHV6803UC dishwasher is starting to pull away from the door every time I open the dishwasher. I took the door off and it appears the installer used some type of adhesive...
First you will need to remove all old adhesives. Fingernail polish remover will remove a lot, but silicone requires scraping, and cleaning with a nail file or such. Then use contact cement. Check the label to find one that is heat and moisture proof.
Nov 25, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
The detergent dispenser sliding door seems to have come detached from the spring. How can I reattach it?
You really don't need it! Try this, load your dishwasher as usual, Fll one cubby with your detergent and put on the shortest cleaning cycle. Thats all I ever use and my dishes are clean. And I'm talking about a inexpensive dishwasher!
Mar 14, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
The water does not circulate throughout the washer. Is the pump bad? The full cycle will run without cleaning.
Before we jump to conclusions, you can try to clear element that discharges the water. The wholes in these units can become clog do to the detergent as well as food. Most Bosch units allow you to unscrew these pretty easily. Blow through them, or use a plastic tooth pick to clear any obstructions or both. Before you reattach, turn on dishwasher and listen to hear how much water is shooting out at the discharge points. Most Bosch have two discharge points one for the top and of course one for the bottom. Reattach units and Run dishwasher.
Should this fail it could very well be the circulating pump.
Oct 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher built in- middle washer unit fallen off
middle rotating washer attaches to the top washer basket and not actually to the dishwasher
Jan 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Upper wash tube assembly came off back of unit. can not reattach.
We had the same problem with our Bosch 4800 and found that the upper wash arm and tube assembly should attach to the bottom of the upper rack (rather than to the back of the dishwasher). The wash arm and tube assembly slides in and out with the upper rack. When the dishwasher door is closed the tube assembly is forced up against the back mounting/water supply.
Nov 30, 2008 | Dishwashers
Bosch Dishwasher
Hi ED, It sounds like a real problem here. If the springs are still in one piece, my best guess is to to remove the springs from the door. Then attach the springs to the dishwasher body first, then reattach the spring to the door. Not an easy job, good luck. If you have further problems check with www.repairclinic.com, as the repairguru there may be of more help.
Sep 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Shu5312uc bosch dishwasher
Since water doesn't drain out,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Aug 02, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
157 people viewed this question
Top Bosch Dishwashers Experts
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Marvin
Marvin
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
