3M ergo BT mouse
Support says it is compatible with Microsoft - Windows XP, Vista and later and Apple MAC OS 10 X v10.4.X, v10.5.X and later. Turn off computer and connect usb and turn on computer it will detect mouse. Link below may help
https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-Wireless-Ergonomic-Mouse-Small-EM550GPS/?N=5002385+3294308590&rt=rud
SOURCE: 3M Projection Panel
Based on your post/description, I will assume that you would want to connect a PC to a Projector.
For a 3M DY-0205-1002-9, pls contact:
3M Customer Information Center
Hale Avenue Business Center
3M bldg. 506, POCS Destination Code 0444
835 Hale Ave. North
Oakdale, MN 55128 Fax: 651-736-6320
or try
3M Visual Systems
1-800-328-1371
(Fax) 512-984-5105
Internet: www.3m.com/presentation
Email: OHP - [email protected]
EPS - [email protected]
Should you opt for a replacement, you may want to consider DVI
to VGA Analog Video Cable or similar products.
Alternately, you can use a converter box that will accept VGA inputs but whose output is DVI-D compatible. A fine example is VGA to DVI Converter/Scaler but of course any comparable brand/model should also work.
Hope that these be of help/idea. Pls post back how things work out or should you need further information.
Good luck and kind regards.
SOURCE: Mouse: Must click 3 or 4 times to "pick" stuff. Highlighting "lets go"
Try compressed air to clean under the button. Alternativly try tapping the sides of the mouse gently on the desk - this could dislodge anything under the button
I don't think its a driver issue but you may as well try it. look for the mouse driver on the 3M web site
SOURCE: I need driver for 3M EM500GPS 3 Buttons USB
Should be plug and play for Vista, XP, and later.
Manual and Information here.
Page GB-12 of manual
Mouse Not Detected
Computer ports are improperly
set up (for example, are disabled).
Conflicts among other devices connected.
Installed on an incompatible operating system.
Check with your computer system dealer or
manufacturer if you need help.
Resolve any conflicts among devices connected to
your computer.
Compatible operating systems for the 3M
Ergonomic Mouse EM550 are listed on page 2.
SOURCE: 3m-X50 Lamp will not light up. Changed lamp.
you have a bad ballast. you'll have to replace it.
SOURCE: 3M model 45CG Thermofax Machine how to change bulb?
On either side of the drive table are single wires that go to each end of the lamp. Remove one screw on each side of the snap-in levers. Turn red handle on left side of unit as you are looking at it. Lift up each lever (screws you just removed) carefully. You can slide the entire unit out from under the clear plastic, then you will be able to see the lamp. It is a long halogen lamp. Do not touch the lamp with your fingers!! The oil on your skin will cause that area to overheat, boil, and blow. Disconnect wires on each side. Loosen bracket screws (2 on each side). Lift lamp out of heatsink tray by porcelain ends and slide out. Replace in reverse order. REMEMBER: DON'T TOUCH LAMP WITH FINGERS. USE GLOVES OR HANDLE BY PORCELAIN ENDS. GOOD LUCK!!
