Question about Video Game Consoles & Games
Weslo crosswalk 5.2 wont start
Console shows "hello" and buttons beep but nothing happens. Brand new unit, connections have been verified
Posted by Mark Sumner on
5 Related Answers
IB4G2008
Patrick Michaels
  • 3587 Answers
SOURCE: Won't power on
sounds like it's showing a bad power situation...maybe the outlet is not too good?
Posted on Mar 24, 2008
Anonymous
SOURCE: Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Posted on Jul 10, 2008
Anonymous
SOURCE: psyclone essentials ps3 wirless remote controller wont connect
just fixed mine. i went to psclones web site ...it doesn't even have the PS3 remote listed a s a product!! however by reading the PS2 manual i figured that if I basically adapted the instructions it might help...I moved the remote to the 3rd slot.. turned off controller switch... held connect button on reciever... turned on controller.... held connect button....held select button ......held down left analogue stick....in no particular order...going back and forth until i noticed the lights had started to go steady... kept holding (30 secs+) Saw a single steady red on 3rd slot...It stayed...Yeh ;O (no clue what was the deciding factor...but theres hope!!) Lesson learned..next time i pay the full price for the Sony remote... Hope this helps
Posted on Jan 05, 2009
Anonymous
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Posted on Mar 13, 2010
Missing a key for Weslo treadmill crosswalk 365e- can you assist? I live in calgary Alberta
Here is a parts list for the Weslo Crosswalk 365e - scroll down to "Safety Key" and that is the part you need. They are pretty cheap so I recommend getting a couple extras in case you lose one again.
Mar 22, 2011 | Exercise & Fitness
I have a black screen when I connect the HDMI cable. When I connected it originally it worked for about 5 minutes but now I get nothing but the black screen. I tried connecting a different HDMI cable to it...
The main reason of HDMI black screen problem due to HDMI cable may damage and not proper connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damage, do borrow your friend cable and have a try. If your friend cable work fine, and the black screen error disappear. Then you can buy a brand new HDMI cable for replacement.
Tips 2: If tips 1 not working, you need to go another step deeper by reset your console. Most of the PS3 gamers not aware that Sony actually done include in the black screen troubleshooting method and other HDMI problems in the PS3 manual, you can find it under troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data in hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed to two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
It won't incline
Hello, Has it done this as long as you owned it? and how did it start acting up? Is it inclined all the way up or is it down?
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jan 09, 2011 | Weslo Pro Crosswalk 7.8 Treadmill
I purchased a weslo pro crosswalk 7.8 it doesn`t have a safety key how do i know which key and where to get 1 thanks bill
hi weslo treadmill keys are mostly the same, i have seen some on ebay selling for under £15.00. or if you contact icon health & fitness 08451770512, these people are the main suppliers of weslo treadmills and parts. they are uk leeds based.
Nov 20, 2010 | Weslo Pro Crosswalk 7.8 Treadmill
I turn my ps3 on, and the main menu never shows up. all i see is that wavy thing (that the menu usually shows up over) and nothing happens. then the only way i can turn the system off is by flipping the...
Ok, what you need to do is re-install the system software, I will talk you through it. WARNING! This will erase your save games and other data you have on the PS3!!
Step 1. Turn the PS3 on at the back but leave it in standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, beep 5 seconds later and then once more 5 seconds after that. Release the power button.
Step 3. Press and hold the power button again. It will beep once when you first press it, beep again 5 seconds later and then about another 5 seconds later it will beep twice quickly. When you hear these 2 quick beeps, let go of the power button.
Step 4. The PS3 will start up and ask you to connect a controller via USB and press the PS button. Do this and then move onto the next step.
Step 5. The recovery menu will load. Select option 5 "Restore PS3 System". The console will go through an automated restore sequence and re-write its software. It will then restart and hopefully after you have entered the time, date and username information start normally.
If you need any more help, please reply here.
Thank you for using FixYa
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
I turned on my ps3 and nothing is happening it is not giving me the option to sign in or anything. just the blue backround nothing else and now it wont let me turn it off.
Sounds like you PS3 software has become corrupt. Follow these steps to sort it but I must warn you, you will lose all your save games!!
Step 1. Turn the PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later then beep once more and turn off. Release the power button when it turns off.
Step 3. Press and hold the power button again. It will beep as soon as you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. As soon as you hear the two beeps let go of the power button.
Step 4. Your PS3 will now boot into recovery mode. Connect you controller via USB when asked and press the PS button.
Step 5. Select option 5 from the recovery menu, "Restore PS3 system". This will rewrite your PS3 software and hopefully should sort your problem.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
Belt wont start on a brand new Sole F80. Motor
Mar 12, 2010 | RTO Sole F80 Treadmill
PS3 Problem... I turned on my ps3 but nothing shows up on the television screen and controls wont even detect... PS3 shows that it is receiving power because the power light on ps3 is green. Can someone...
Turn the power off on the switch on the back, and then back on again. Hold down the power button, keep on holding it down after the first beep, but let go once another couple of beeps sound. It should then take at max a minute but then it should show a screen set up section.
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Problem with FAV6800AWQ model.
Hello jcgraham75,
Just to let you know the control board is a warranty part for 5 yrs. Look in the back of the FAV6800A/9800A Service Manual if you don’t have your original documentation for your FAV6800AWQ. You will find warranty info and the customer service phone number. Have your serial number and model number handy. That info is on the back right side of the console. Good luck
Mar 25, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
44 people viewed this question
Top Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
