Do you think MP3s sound as good as store-bought CDs?
Posted by Curt Mueller on
Dagdamor
    New Friend:
They do not in my honest opinion. You can here the difference caused by the sampling rate on high end systems. Usually higher frequencies aren't as crisp.
Posted on Apr 03, 2019
  • Curt Mueller Apr 03, 2019
    The sound seems to be compressed and definitely loss of highs.
Greg Peyton
    Habit-Forming:
    New Friend:
  • 61 Answers
That might have as much to do with the vintage of each. Assuming that both are the latest technology, then I have read that there is very little difference.
What could be causing this unit to eject CDs?
What brand, model #? There should be a small pinhole in the face plate to reset with a paperclip this may or may not help.
Aug 15, 2014 | Car Audio & Video
Hello i just bought a phillips mp3 cd played, just want to know if its an actual mp3 player or just plays cd from mp3 file
Phillips does not make a hybrid cd / mp3 device. If you are able to insert a cd into the device and play it then it can only play audio cds and audio cds with mp3s on it. That is to say, it is not your standard MP3 player like an iPod etc. It is a cd player that can play mp3 cds.
Feb 28, 2011 | Philips Audio Players & Recorders
No sound on cd's, dvd's sound fine
Read your Manual. It might not play Reg,CDs or it will only play MP3s. Hope this Helps
Apr 16, 2010 | Insignia NS-H2001 Theater System
Cd Burner says its burning CD but after finished the cd will not play in anything
Sounds like the CDs need to be finalized. Also, if you are burning MP3s, make sure your radio is compatible with MP3s.
Nov 26, 2009 | Office Equipment & Supplies
My cdx sounds really terrible
hello
faced the same pb only with MP3s audio tunes burnt on cds (crackles..pops ect ) - no prob with normal cds
Nov 23, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
There is no sound on this game? Or is it just
Check to see if it's not mute. Go into the Contol panel for the sound and check the setting ther. Make sure that all the right devices are in order. You can also check to see if other media will pla....mp3s, cds, dvd, etc. Use "process of elimination" to determine the cause.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Origin Anacapri the Dream for Windows
Wont read some discs
People need to learn to leave more info if they want proper help!
What type of discs? You say some, are they CD-R, CD-RW, SACD, CD+R, CD+RW, standard store bought Audio CD?
When copying audio cds for playback in other players, always use CD-R to avoid any type of confilcts. CD-R will play in almost any CD player, even from the 80s. Some players say they will support CD-RW, but that is NOT GUARANTEED!
If it is Audio CDs, then the laser may be dirty. If it is MP3 cds or DATA cds, then try only putting one type of file on the disc, such as only MP3s, or only WMAs.
Oct 01, 2009 | Denon DN-S3000 Turntable
Vmp508 verge cd player/in dash car stereo
Mine was doing the same thing for a while. I put in one of those special CDs that have little tiny brushes on them that are used to clean the laser. And after that it worked. It still does it every once in a while, but not very often. It seems to like mp3 discs more than regular CDs. But be sure to DISABLE MULTISESION when you burn your mp3s. Otherwise it will DEFINATELY give you the error 2 message.
Dec 20, 2007 | Verge VMP508 CD Player
Kenwood DPX501 won't play mp3s that are burned onto disks
Does' it do both plus and minus cd's? It may only do CDR+ or -
Aug 13, 2007 | Kenwood DPX-501 CD Player
XDM6825 Not Playing MP3s in Stereo
if you have a FM MODULATOR installed too,some ones no transmiting in stereo mode, try changeit
Feb 14, 2007 | Dual XDM6825 CD/MP3/WMA Player
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
