Question about Westclox Audio Players & Recorders
I took my dialite westclox bold2 apart to repaint it. Some how I forgot where the electric wires connect.
Posted by Kevin Akers on
Greg Peyton
    Habit-Forming:
    New Friend:
  • 61 Answers
Could you provide a close up of the clock unit itself? There may be a couple of holes in the clear plastic where the wires can be inserted into.
Posted on Apr 03, 2019
2 Related Answers
co7196
Ned C Cook
  • 3433 Answers
SOURCE: electrical
ok, what I meant was is it a live wire. Assuming it is and setting it aside, The other three must be leaving the switch. Hot in and three out for different speeds. The speeds are controlled downstrean on each wire either by resistors or motor design. The fan motor(s) are grounded at their mounting locations. So, touch the hot wire to each of the others one at a time to confirm. Then, turn the switch to low and insert the hot wire into a terminal until the one that that turns the fan on is found. Turn the switch off to confirm control and then turn switch to confirm control of the other two speeds. No need to worry about shorting anything, The ground would be your only fear and it's far remote. Good luck
Posted on Jun 25, 2009
Ted Maxwell
  • 3519 Answers
SOURCE: I took apart the color wires connector harness goin to the motor and and the switch and now i forgot how the wiring harness connect back do they all go to the same colors?
As a normal procedure, wire colors always match through a connector.
Posted on Mar 27, 2016
1helpful
2019 GE GTD72EBPN0DG electric dryer, took front off and dropped it ripping wires apart.
Question edited for clarity.
Question moved from Cars and Trucks category.
Did you look inside the back console where the control knob is for the wiring diagram? They are normally inside there in a plastic bag.
It is only for the door switch, so it is just a two wire, open / closed circuit. Join blue to blue, and pink to yellow.
There are generic GE Door Switch replacement videos here.
https://www.google.com/search?q=gtd72ebpn0dg+replace+door+switch
https://www.google.com/search?q=GTD72EBPN0DG+door+wiring+diagram
Aug 25, 2022 • GE Dryers
How can i repair chaging pot bold 3
the charging port is broken and you cannot fix it but what you can do is cut your charger find pos neg wire and connect to battery terminals
1helpful
I Got a motion sensor light on my outside porch well i took it all apart to repaint it now i am confused as to were all the wires go i have 2 that come off lamp post black and white and 3 that come of...
all white wires go together,the hot wire from the switch goes to the black of the sensor and the red connects to the black wire from the light sockets
Orange wire
look in the wire schematics that came with the dryer or look them up online. They should tell you what that wire is for.
Timer
I have seen a similar question before. Look up the wire schematics and see what that wire is for. The sire schematics usually come with the dryer.
2answers
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Top Westclox Audio Players & Recorders Experts
nexrad_chris
Ngoro
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
