Measuring Tools & Sensors Logo
Question about Measuring Tools & Sensors
Blue star vrf outdoor temp sensor show me now
Posted by Syed javeed on
2 Related Answers
windryder
  • 22 Answers
SOURCE: i have this model and the outdoor temp sensor isnt
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Posted on Nov 30, 2011
  • 19166 Answers
SOURCE: I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Posted on Apr 01, 2018
I am Having Panasonic VRF 10 HP with 10 INDOOR UNIT MODEL NO. U-10EA1E8 AS MY INDOOR UNIT GIVE ERROR CODE F27-01 ,OUTDOOR UNIT STARTS BUT THE FAN MOTORS DO NOT START ANY SOLUTION U CAN SUGGEST
Temp sensor, bad motor, bad control board…too complex you need help. Your outdoor unit will have a better diagnostic code to hopefully narrow the problem but this requires opening of machine.
Mitsubishi vrf 2500 error
Blue star vrf error code f1. F9. F0 E5
L7 error coming on m vrf blue star
Blue Star vrf caset ac L7 error not indoor opret
Jan 10, 2018 • Cell Phones
2answers
Blue Star vrf 21 error code what happened
VRF unit blue star a/c out door error code Erroc. Plz answer me sir
Top Measuring Tools & Sensors Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
