Question about Zebra S4M Thermal Label Printer
The label prniting is not work properly, print two
The maquine label is printing not work properly, Descripance: the maquine print two label good and the next label is moved my data barcode on the half on the next label! what you recomended?
Can I calibrate manualy this machine or have other form to calibrated?
Regards
Frank
Posted by frank_delaro on
Anonymous
    Problem Solver:
  • 13 Answers
You can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Posted on Sep 05, 2009
Not printing properly
Printhead should be cleaned with a 90% alcohol solution, however that should not cause blurry print. I've seen some labeling programs that will blur part of your label after the trial period has expired. I would check to see if this happens on test prints also. Do a test print by holding down the button on power up and letting it go after the first blink.
Jun 09, 2015 | Zebra GK420D Direct Thermal Label Printer
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
I'm trying to print the cd label on the label paper but it's offset and won't print in the right area. I calibrated the printer but it still won't work.
Some CD label software allow you to adjust the "overprint" by resizing the image you are printing. If your software doesn't allow you to size your image larger than the label (so it overlaps) try a different program. Look for a setting that allows it to over print. It's not an exact science...you just have to try to make the adjustments you need. There are also different CD/DVD label sheet types where the labels are setup on the sheet differently. maybe a different setup may work better. However, usually Avery is pretty good.
Jun 12, 2010 | Avery DesignPro Deluxe CD-ROM...
Have been using Samsung Label printer SRP 77011since last one year. Of late we have been observing that the print on the labes fade in a few days. What could be the cause and the possible solution for the...
Most likely it is a quality issue with the label you are printing on. As long as the image is printed good initially onto the media(thermal paper), the printer/software portion of it is done.
Thermal paper has a special coating and protective layer to prevent it from fading from exposure to heat, including light. But if the coating is bad then it'll show problesm like you describe
Apr 29, 2010 | Samsung BIXOLON® SRP-770II Thermal Label...
PRINT LABELS
You will need to use the manual feed slot which is above the paper tray.
The manual feed is meant for labels and envelopes
Dec 02, 2009 | Brother HL-5240 Laser Printer
Labels print out of center
the important thing is if you are using different type labels and sizes before printing see to it that the labels must properly calibrated..to avoid printing incorrectly
Jun 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Label Printing
On the subject of <a href="http://www.selfadhesivelabels.com/label-printing.html">label printing</a>, i actually get all my labels printed by a british labels company for a really low price. If anyone is at all interested then it may be worth taking a look at their website as they do all types of label printing.
May 01, 2008 | Samsung CLP-550N Laser Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Aug 06, 2007 | OKI MICROLINE® ML390 Matrix Printer
Zebra S4M Thermal Label Printer Logo
806 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
jdthefixer
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
